Everyone with corvette c4 wheels!!!!
Old Mar 12, 2012 | 09:44 PM
Adamo41188's Avatar
Adamo41188
If you have them chime in asap!
Basically I'm looking to buy a set soon, they look great and they are all over Craiglist for dirt cheap.
I want to know everything so I know what to run.
Are you using....
16s or 17s?
What offset?
What width?
What adapters?
What tire size?
Any and what mods done to clear from rubbing etc.
Its hard to find info on these things so I figured I would give this a shot! thanks guys!
Old Mar 13, 2012 | 04:30 PM
Adamo41188's Avatar
Adamo41188
anyone? :(
Old Mar 13, 2012 | 06:26 PM
Minian's Avatar
Minian
Originally Posted by Adamo41188
anyone? :(
Do a search, you'll find a few pics. You also might want to ask StanceDesign.
https://www.northamericanmotoring.co...ged-minis.html
Check out Corey Kelty's pics
Old Mar 13, 2012 | 06:42 PM
Adamo41188's Avatar
Adamo41188
Thank you! Ive been looking for people with them on here but had no luck. Ill message them.
Old Aug 28, 2012 | 08:56 PM
knipdlo's Avatar
knipdlo
Did you ever get an answer on what were the right wheels/adapters/etc to do this?
Thanks!
Old Aug 31, 2012 | 11:09 AM
C4RACER's Avatar
C4RACER
this makes no sense - Corvettes use 5 lug, and these wheels are 8.5 to 9.5" wide too.
Old Aug 31, 2012 | 02:54 PM
fenderless 33's Avatar
fenderless 33
Thanks C4racer I wasnot folowing this either. What does a vett wheel have to do with a MINI?
Old Aug 31, 2012 | 04:47 PM
C4RACER's Avatar
C4RACER
wrong forum is the only thing I can think of
Old Aug 31, 2012 | 06:10 PM
Minian's Avatar
Minian
Because they look good on a Mini. http://scrapedcrusaders.files.wordpr...1/09/mini1.jpg
Old Sep 1, 2012 | 05:17 AM
Hyland33's Avatar
Hyland33
Post on motoring underground. You'll get an answer there instead of confused people lol
Old Jan 12, 2017 | 12:36 PM
MiniMello's Avatar
MiniMello
plenty of pics of the swap must be one hell of a spacer set up to fit them
Old Jan 18, 2017 | 01:19 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Are you using....
16s or 17s?
What offset?
What width?
What adapters?
What tire size?
Which MINI do you have? R53, R56 or something else. This is important because the wheel bolt or stud for each is different thickness/diameter and thread pitch which will be a problem for a wheel adapter 4 lug to 5 lug conversion. R56 is the problem, R53 the earliest MINI or R50 is fine.
see discussion
http://www.motoringunderground.com/f...ad.php?t=22099
Can be done.
barnoun
Sep 17, 2018 05:04 PM
khumpert
Nov 30, 2015 11:48 AM
SosoMINI
Nov 22, 2015 03:17 PM
theblackfalcon
Oct 11, 2015 09:49 AM
Tires, Wheels & Brakes
Aug 26, 2015 11:02 AM
