Wheel brush suggestions
To keep wheels clean, I would use some Prima Hydro which is super easy to spray on. Or Prima's Wheel Shield for more durable protection. This will enable you to rinse off brake dust even easier. Often a quick swipe with a microfiber towel will do the trick, without water. Wheel brushes become unnecessary.
However on wheels with stubborn brake dust I use a brush with soft flagged ends. For the barrels, EZ Brushes are nice. But I'd say the best way to clean the wheels is to just use a non acid wheel cleaner like Sonax Full Effect. Spray it on, wait 3-4 minutes, and rinse it off. In the video here, I'm using a less than desirable sprayer from Ace Hardware. I've found that a Solo bug sprayer works awesome and lets you mist the FE on in seconds.
depends
i use a boar's hair brush when it gets stubborn with some simple green, apply fresh wheel armour after and then just use hydro or slick and a black microfiber towel to clean regularly.
As far as brushes go many good suggestions to getting in the tight spots of the wheels. Thanks!!, just the info I was looking for.
I tried a wheel brush but found that it wasnt easier to use and did a poor job in general. I use Griots wheel cleaner, a mitt just for the wheels, and Griots 3 finger mitts to get in the small spaces. Its fast and does a great job. The 3 finger mitts allow you to get into the spaces behind the outer wheel surface.
Interior/Exterior R53 Speedometer Replacement
maniacalmorgan
Aug 21, 2015 03:03 AM
R50/53 R53 Speedometer Replacement
maniacalmorgan
Aug 20, 2015 01:08 PM
sabjcw
Aug 14, 2015 07:40 AM
