R50/53 stuck hatchback
Old Mar 5, 2012 | 11:49 AM
bahman's Avatar
bahman
stuck hatchback
Does anyone have experience with stuck hatchback on 2006 R53? It does not respond to locking/unlocking with the key, nor with the toggle switch.
Old Mar 5, 2012 | 12:10 PM
Stanislaus's Avatar
Stanislaus
2003 R50 here, but I know there's a wiring connector leading to the release located behind my hatch cover. If it came loose you'd have that problem. Do you hear it clicking or is there nothing? Did you recently do anything to the rear wiper?
In my car there is an emergency release cable for the hatch under the passenger side rear seat (a bowden pull cable). If you have that you can manually release the hatch to get a better look at the situation.
Old Mar 5, 2012 | 04:22 PM
bahman's Avatar
bahman
Thank you, Stanislaus. Most likely the problem is as you have described. I hear no clicks, etc. when I depress the recess under the lid handle. I'll go ahead and release it manually as you have described, and then diagnose the problem.
Thanks again.
Old Mar 5, 2012 | 05:04 PM
Stanislaus's Avatar
Stanislaus
No problem! I hope this helps/is your issue.
The part of the wiring harness that meets the door latch switch is #37 0n this diagram, though it's not actually shown-it's just a push-down-and-release clip type connection.
http://voxcrisp.blogspot.com/2012/03/blog-post.html
Old Mar 6, 2012 | 09:23 AM
bahman's Avatar
bahman
Stanislaus,
Thank you for the additional info. I tried it, and the problem was loose connection to the handle. Pushed it in, and it works fine now.
Thanks agian.
Old Mar 6, 2012 | 09:59 AM
drsimmons's Avatar
drsimmons
What a great place this is.
Old Mar 6, 2012 | 02:39 PM
bahman's Avatar
bahman
Indeed!
scottselk
Jul 20, 2019 06:43 AM
pglgp1292
Oct 5, 2015 09:34 PM
MINI Stupor
Oct 1, 2015 11:36 AM
Tires, Wheels & Brakes
Oct 1, 2015 08:55 AM
Samhillrocks
Sep 29, 2015 12:55 PM
