Replace valve cover gasket
Old Mar 2, 2012 | 08:25 AM
Applesauce's Avatar
Applesauce
I have a *very* slow leak (more like an accumulation) around my valve cover, and am going to replace the gasket this weekend sometime. I figure the gasket is cheap, and I'm changing my oil anyway.
Is there anything in particular I should look out for? I don't think the cover is cracked, but I do know that this is common. I'll check it out when I have it apart.
What holds the valve cover on? Are they bolts or studs? Should I replace them when I replace the gasket? Can I just use standard metric hardware, or do I need something proprietary? Thanks!
Old Mar 2, 2012 | 08:32 AM
rustyeuro's Avatar
rustyeuro
The valve cover is held on by long bolts, which i have been told should be replaced when you do the head gasket. I personally wouldn't use generic hardware (too many things that could go wrong)
FEL-PRO Part # ES72272 set of 8 $17.77
on Rockauto.
hope this helps, I need to do this too someday soon (when the snow is gone)
Old Mar 2, 2012 | 03:01 PM
redhotchilipepper's Avatar
redhotchilipepper
I lived and learned after my valve cover gasket replacement..Get yourself some deep sockets because as the prevous post says it's held on with verrrry unique long collar bolts. A few tips after doing mine...1)be careful disconnecting the wire brackets from the valve cover bolt studs so you dont break them --2)DO NOT forget to replace the four spark plug seals located on the top of the valve cover!!--3)do not over torque the valve cover bolts, they are extremely flimsy and a pain to find anywhere but a dealer...--4) take your time and have fun
Old Mar 2, 2012 | 06:09 PM
Applesauce's Avatar
Applesauce
Thanks! This was really helpful. I popped one out today before ordering all the necessary parts at my local shop, and it is indeed not similar to a head bolt; I'm sure I'll be safe reusing them. And I've got all the requisite tools, including deep sockets and lightweight 1/4" torque wrenches...
Just curious: did any treat the threads on theirs on reassembly? They're very low-torque bolts (9 ft-lb), and have funny rubber boots on them; I can't quite figure out what keeps them from rattling out...
I noticed when I removed the one today that my cover might be cracked. I'm still hoping it's just seaming in the plastic, but we'll see. Fingers crossed!
Old Mar 5, 2012 | 03:52 PM
Applesauce's Avatar
Applesauce
Job done. I took pictures and will write a how-to in the fairly near future. Any questions in the meantime, please let me know!
Old Mar 5, 2012 | 05:22 PM
rustyeuro's Avatar
rustyeuro
did you happen to take a picture of these rubber things on the bolts?
and a preemptive thanks for the DIY
Old Mar 6, 2012 | 06:13 AM
Applesauce's Avatar
Applesauce
I did, but not super macro or anything. Think of them as VERY fat o-rings. The valve cover bolts are like ultra-mini versions of the coil pack bolts: they have the same pressed-on t-washers that limit the amount you can compress the valve cover; thus if your gasket is leaking, it's most likely NOT related to bolt torque. DIY to follow!
Old Mar 6, 2012 | 08:18 AM
redhotchilipepper
Not too sure how to upload pics so I hope this works. Here is the valve cover collar bolt.
Old Mar 6, 2012 | 08:56 AM
rustyeuro's Avatar
rustyeuro
interesting
Old Mar 10, 2012 | 11:16 AM
rustyeuro's Avatar
rustyeuro
did you make a DIY yet
i was looking at mine and i'm not excited to have to remove part of the fuel rail (it 's sitting over one of the bolts)
Old Mar 16, 2012 | 09:09 AM
Applesauce's Avatar
Applesauce
Sorry about the delay! DIY should be up soon, pending moderator approval... I wish it weren't so, but it is so. So just be patient.
Old Mar 16, 2012 | 09:32 AM
rustyeuro's Avatar
rustyeuro
sounds good, i'll probably be working on this in a week or two
09R56
Nov 16, 2022 10:49 AM
bobbiemartin
Jan 20, 2016 05:28 PM
azntaiji
Aug 13, 2015 03:24 PM
OutMotoring
Aug 6, 2015 09:32 AM
eliseo1981
Aug 6, 2015 05:00 AM
