R60 Question on how to waste gas
Old Feb 22, 2012 | 06:29 PM
NickyD999's Avatar
NickyD999
Sarcastic subject line but it is sort of the truth in my case. I have a Mastiff that travels everywhere with me. On hot days there are times when I need to leave him in the car for 10-15 minutes. On my old truck it was easy, I left it running with the A/C blasting for my big guy and was able to lock the truck and unlock it from the outside with the keypad on the door.
With the Countryman it looks like that might not be as simple. Can the second key fob be used to lock/unlock the car while the other one stays in the ignition to keep the car cooling? I do not have the comfort access if that makes any difference.
Thanks,
Nick
Old Feb 22, 2012 | 07:04 PM
Mojito's Avatar
Mojito
I'm not sure, but I have been able to leave the fob in the ignition while removing the physical key. Haven't tried locking it by the key yet, but worst case someone could steal the car but not be able to restart it again
Old Feb 22, 2012 | 07:08 PM
chrunck's Avatar
chrunck
I don't see why it wouldn't work with two fobs. Have you tried? Seems like it would be much quicker to test than wait for a reply here.
chrunck's Avatar
chrunck
Pretty sure you don't need the physical key to start the car.
Old Feb 22, 2012 | 07:12 PM
NickyD999's Avatar
NickyD999
I don't have the car yet I pick it up on Monday and this just popped into mind.
So there is a standard key that is part of the fob that is removable? If that's the case it sounds like I should be able to leave the car running and lock the vehicle with the standard key from the outside, no?
Old Feb 22, 2012 | 07:55 PM
DR61's Avatar
DR61
I don't have my car either, but the manual PDF shows that there is an integrated key inside the remote (an old-fashioned 'real' key) that releases by pressing a small button on bottom of the remote. You are supposed to be able to lock/unlock the car door using this integrated key in the door key hole.
Old Feb 22, 2012 | 09:17 PM
coopers111's Avatar
coopers111
I don't have comfort access just the regular key fob and I discovered that I can leave my car on and take the key fob, close the door and lock it. Here's how I do it.
Open door.
Enter car.
Close door.
Start car.
Shut car down. (don't open any doors)
Remove key fob. (don't open any doors)
I have a max of 6-8 seconds to push the start button and car will start without the key in the slot.
Open door (car still running)
Exit car (car still running)
Lock with key fob (car still running)
Enjoy (car still running)
I can always do it as long as the doors are closed when I shut the car down and do it right away; shut down, remove key fob, press start and it'll turn on and then I can do whatever I want (open doors and lock and unlock with the key fob). Hope it helps!
Old Feb 22, 2012 | 11:23 PM
ChubbyMini's Avatar
ChubbyMini
What if u insert fob start car and remove fob without hitting the stop button? I was able to do that with my Murano
Old Feb 23, 2012 | 01:18 AM
beauxgoris's Avatar
beauxgoris
On a side note: do you get just one key fob or two with your car?
Old Feb 23, 2012 | 02:41 AM
ChubbyMini's Avatar
ChubbyMini
We are going to get two fobs.
Old Feb 23, 2012 | 07:38 AM
coopers111's Avatar
coopers111
If I start the car I can't remove the key fob until I press the stop button.
Old Feb 23, 2012 | 08:22 AM
DR61's Avatar
DR61
New cars come with two remote key fobs and can use a maximum of 3 remotes according to the manual PDF. However I've read that buying a remote is expensive, so take care not to loose any.
Old Feb 23, 2012 | 10:13 AM
yetti96's Avatar
yetti96
Open door.
Enter car.
Close door.
Start car.
Shut car down. (don't open any doors)<------------------------
Sounds like a pain but I will give it a try.
Old Feb 23, 2012 | 06:29 PM
kunzman's Avatar
kunzman
You don't have to have the key fob in the dash for the car to start. It just has to be in the car.
Old Feb 23, 2012 | 06:34 PM
drmsmiller's Avatar
drmsmiller
Yes, I have tested that out and found it to be true.
Old Feb 23, 2012 | 07:07 PM
NickyD999's Avatar
NickyD999
Awesome, thanks everyone. I will go about it using the old fashion key rather then the start and restart trick. For some reason it seems wrong to me to start a car and then just restart it. Can't explain it but as long as there is an old fashion key it will do.
Old Feb 23, 2012 | 08:16 PM
52804x4's Avatar
52804x4
I believe that is only if you have the comfort access package.
W0TM8
Dec 19, 2019 07:50 AM
TBRoye
R55 :: Clubman Talk (2008+)
Aug 24, 2015 08:41 PM
missinmyjeep
Aug 22, 2015 07:13 PM
dchang0
Aug 10, 2015 03:37 PM
WayMotorWorks
Aug 4, 2015 01:47 PM
