R50/53 Buying 145K miles 2005 Cooper S
Old Feb 16, 2012 | 07:20 AM
Honomatsu's Avatar
Honomatsu
Hi everyone,
Thank you in advance, I'm NEW to Mini and need your advice.
I've been looking GTI, Mini, or Rabbit S, and found a high mileage (145K) 2005 Cooper S.
Please advise on following areas:
1) Anything particular to look or ask the owner other than basic stuff?
2) Is there timing belt to replace on 2005?
3) Water pump?
4) Transmission?
5) He said that he installed High performance clutch (heavy to step)
6) Any electric devices to fail?
Any other advice or suggestions?
Again, thank you!
Honomatsu
Old Feb 18, 2012 | 09:31 PM
trickpat35's Avatar
trickpat35
I would ask about the timing chain when maintenance has been down, if the chain-tensioner has been replaced and about the Belt tensioner as well. Also I would ask if the supercharger has been maintained (oil checks) or if it has been replaced in the past (i would look at failed superchargers on here to get a better understanding) if it has been replaced ask if they replaced the water pump at the same time. Those would be the questions I would ask about since those are the parts to fail most it seems. Along with the power steering pump but that just makes a high pitch whine which is super annoying haha
The transmission is pretty stout I feel. Just make sure it shifts smoothly with no grinds and that should be fine.
Use your best judgement, I personally stay away from high mileage cars but if maintenance has been kept up with it should be a fun car.
Old Feb 20, 2012 | 07:26 AM
Honomatsu's Avatar
Honomatsu
Thank you trickpat35! It was my mistake that I posted it twice. Please see the other one.
http://tinyurl.com/869ysua
You mentioned about the timing chain, but I hope it's wrong...Thank you again!
iggi
18
Feb 9, 2026 01:00 AM
Toolman
Jan 20, 2016 06:50 AM
mdutton11
14
Oct 26, 2015 01:47 PM
phrza81
Oct 10, 2015 11:37 PM
xpunisherx
Aug 10, 2015 10:50 PM
