R50/53 intake manifold hose connection help
Old Feb 14, 2012 | 08:32 AM
kb30's Avatar
kb30
quick question
how do you remove the hoses from the intake manifold? I busted my sucking jet valve and lost my brakes and need to remove the connection that leads to the intake manifold. thank you in advance!!
Old Feb 14, 2012 | 08:51 AM
BlwnAway's Avatar
BlwnAway
Just push down on the ring itself, then pull on the hose.
Old Feb 14, 2012 | 09:10 AM
kb30's Avatar
kb30
ok Thank you i was weary of damaging the connector i pulled on it for little bit. i damaged the sucking jet pump moving my intake around and needed to remove it for replacment.
again, thank you very much!!!
Old Feb 14, 2012 | 01:39 PM
BlwnAway's Avatar
BlwnAway
I'm sure this doesn't have to be said but why not, re-assembly, just push the tube in, no need to push the ring down for that.
Old Feb 14, 2012 | 06:15 PM
kb30's Avatar
kb30
Thanks lol i was thinking about that. I cut my hands up its in such a bad spot down there.
MasterShaftner
Sep 1, 2017 07:23 PM
bobbiemartin
Jan 20, 2016 05:28 PM
HaveATank
Sep 4, 2015 08:04 AM
Inziladun
Sep 3, 2015 10:35 AM
Indimanic
Aug 19, 2015 11:08 AM
