Scary situation on highway
Old Feb 7, 2012 | 12:50 PM
stt816's Avatar
stt816
On my way to class today I was on the highway cruising at about 65mph. All of a sudden my car stops accelerating and the gas pedal is not responding. I was in the second lane and barely got off the exit. I had to roll to the side. I then heard loud rumbling from the back... Maybe the exhaust? I restarted it and it drove normal again but now I hear rattling coming from the back of my car... I'm at 104k miles what can this be??!?
Old Feb 7, 2012 | 01:46 PM
GoThingNC's Avatar
GoThingNC
That is scary !!
Does the MINI have an accelerator cable or is it "Drive-by-wire"?
Old Feb 7, 2012 | 01:50 PM
ACallahan's Avatar
ACallahan
I would guess exhaust related problem too, maybe catalytic converter is shot ?
Old Feb 7, 2012 | 05:01 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Kinda sounds like a chunck of your cat dislodged itself momentarily blocking the exhust causing the initial power loss, then repositioned itself in back near the resonator...
Old Feb 7, 2012 | 06:06 PM
stt816's Avatar
stt816
yeah, maybe. but it is still rattling
Old Feb 7, 2012 | 06:32 PM
veggivet's Avatar
veggivet
Any codes thrown? A bad cat will usually throw a code.
Old Feb 7, 2012 | 06:33 PM
veggivet's Avatar
veggivet
Originally Posted by GoThingNC
That is scary !!
It is drive-by-wire.
-=gRaY rAvEn=-
Moderator
At least your already have an aftermarket cat back so you should be able to access it via the rear clamp.
Old Feb 7, 2012 | 06:35 PM
-=gRaY rAvEn=-
Moderator
It not a perfect science with these things. Have seen chuncks of the ceramic inside crack and break off creating all sorts of accelleration issues and not a code present.
Old Feb 7, 2012 | 06:41 PM
stt816's Avatar
stt816
well i have been getting an intermittent "SES" light popping up. Don't know if it's from this problem though. Usually when I first start driving it bucks really hard. That might be a whole different problem on its own though...
Old Feb 7, 2012 | 06:46 PM
veggivet's Avatar
veggivet
Yup...that's why I said "usually".
Doc Pain
Mar 10, 2021 04:50 AM
jeri534
Nov 6, 2015 01:40 PM
randeez
Oct 5, 2015 09:23 AM
dutchhome
Sep 30, 2015 07:17 AM
