R50/53 Aux input issue???
Old Feb 6, 2012 | 09:30 AM
minimic's Avatar
minimic
Aux input issue???
I've noticed that when I'm using my AUX input with my iPhone and also charging it with the cig lighter, the AUX works for about a minute and then completley goes out and I can only select Radio or CD. AUX is nowhere to be found!!! I thought my AUX might need replacing, but came to this conclusion the other day when I was charging my phone while listening at the same time. I first noticed this on car trips. Has anyone else had this issue or is my Aux input in need of replacing?
Thanks for any info on this!
Old Feb 6, 2012 | 10:49 AM
rkw's Avatar
rkw
It's a common problem. The solution is to use a ground loop isolator such as this. For more information, search the forum for "ground loop isolator".
Old Feb 6, 2012 | 11:35 AM
minimic's Avatar
minimic
Thanks rkw! I wounldn't have known to search for that.
Old Feb 6, 2012 | 01:47 PM
Capt_bj's Avatar
Capt_bj
discussed several times in the nav' and audio section
not mentioned to 'dis you
but to point out some questions are better researched in specific forums . . .
audio questions? see the audio area . . .
W0TM8
Dec 19, 2019 07:50 AM
surfblue
Oct 24, 2018 01:20 AM
khumpert
Nov 30, 2015 11:48 AM
Chippawaguy
Electrical
Nov 8, 2015 08:27 PM
tippin
Aug 5, 2015 08:43 AM
