Front Motor Mount Replacing
Old Feb 5, 2012 | 11:17 AM
dg110270's Avatar
dg110270
I have an R50 06 just a cooper. Does anyone have a DIY guide to replace the hydrolic front motor mount and the torque settings for the 18mm and 16mm nuts and bolts envolved and the torque on the E12 Torx bolt on the bottom of the mount? A friend suggested to remove the 18mm nut on top of the mount and jack the motor up to clear the mount. Where do I put the jack stands to do that?
Old Feb 5, 2012 | 12:41 PM
MINIdave's Avatar
MINIdave
Raise the front end of the car and put the jack stands under the jacking points on the sides of the car, then use your jack to lift the motor slightly.
Torquing the bolts isn't critical, just get them tight.....
Old Feb 5, 2012 | 12:43 PM
dg110270's Avatar
dg110270
Do you know the torque settings? Can I lift the front of the car (both wheels off the ground) from one point with one jack and then put the stands on each side?
Old Feb 8, 2012 | 01:35 PM
dg110270's Avatar
dg110270
I got the new motor mount in today. Thanks for the help MINIdave.
Cereall
Sep 5, 2019 06:05 PM
tr3y003
Oct 22, 2015 10:48 AM
JPMontes3
Aug 23, 2015 01:26 AM
minipopkart
Aug 13, 2015 05:22 AM
