P0336 - Crankshaft Position Sensor
Old Feb 2, 2012 | 09:21 PM
luppie's Avatar
luppie
My 07 Mini is sick and has the following OBDII codes:
P0336 - Crankshaft Position Sensor A Circuit Range/Performance
P1786 - Manufacturer Control
P1321 - Manufacturer Control
Does this means the sensor is bad? I had noticed in several member's posting pix that the sensor is below the exhaust manifold. It seem that I will have to remove the radiator and the exhaust manifold to get to the darn sensor.
BTW, what is the best shop manual for a '07 Mini? Is it the ultra expensive Bentley's manual? Is there a Hayes or Chilton manual for this car?
Old Feb 2, 2012 | 11:49 PM
Gamm's Avatar
Gamm
I once had a P0336 code. A few days later the car went truly nuts as if it was heavily misfiring. A few dashboard lights came on aswell.
After restarting the car it was fine again... for about 5 minutes. After replacing the sensor I've never had this issue again.
Therefore I suggest you to replace it before it causes your car to stall completely like mine did.
patsum
26
May 29, 2021 06:29 PM
shorenetworks
Nov 4, 2019 06:18 PM
CRC
Dec 26, 2015 11:30 AM
renchjeep
Sep 6, 2015 01:54 PM
Sep 3, 2015 02:06 PM
