R50/53 Front end bolt torque specs?
Old Feb 2, 2012 | 08:45 PM
IQRaceworks's Avatar
IQRaceworks
I have searched NAM and haven't had much luck. I'm in the process of installing new LCA bushings, camber plates, and all new koni shocks. I was wondering if anyone had a link or info that would give me the proper torque specs for when I put everything back together. Subframe bolts. Bumper nuts, shock mount bolts...stuff like that.
Thanks?
Old Feb 3, 2012 | 04:53 AM
Hound_va's Avatar
Hound_va
I don't have my book handy, but with all of the stuff you're trying to do a Bentley manual would be a good investment for you. They sometimes show up in the Marketplace or you can get them directly from Bentley Publishing.
Old Feb 3, 2012 | 08:16 AM
Evasive's Avatar
Evasive
Suspension
https://www.northamericanmotoring.co...ll-how-to.html
LCA
https://www.northamericanmotoring.co...g-install.html
Subframe (had to pull out the Bentley)
Control arm bracket to chassis - 59Nm (44 ft-lb)
Front subframe front mount to chassis - 100Nm (74 ft-lb)
Front subframe rear mount to chassis- 100Nm (74 ft-lb)
Lower engine vibration Damper to engine bracket - 100Nm (74 ft-lb)
Lower engine vibration damper to front subframe bracket - 100Nm (74 ft-lb)
Lower steering shaft to steering rack 21Nm (15 ft-lb)
Power steering reservoir bracket to bulkhead 8Nm (6 ft-lb)
Power steering reservoir to bracket 5.5Nm (4 ft-lb)
Bumper
Front bumper carrier to frame or to crush tube - 22Nm (16 ft-lb)
Crush tube to front subframe - 100Nm (74ft-lb)
Old Feb 4, 2012 | 07:38 AM
THE ITCH's Avatar
THE ITCH
Just a quick note that the spec on the Controll arm bracket to chassis is
44 ft-lb plus 90 deg +/- 15 deg. This is also a stretch bolt with a one time use and should be replaced.
Steve
Old Feb 11, 2012 | 07:07 PM
honda93's Avatar
honda93
Glad this came up. I didn't have the shop manual when I installed the Alta 22mm rear sway bar. All went well, but I had my torque wrench set to 90 ft/lbs only to discover afterwards that the rates for the rear subframe bolts should hover around the 75 ft/lb mark.
Is overshooting this rate by 15 ft/lb going to ruin anything? On Honda's, it wasn't a big deal on larger bolts, but this is my first go around with MINI's.
Old Feb 11, 2012 | 07:57 PM
Evasive's Avatar
Evasive
You'll be fine
Old Feb 18, 2014 | 09:32 PM
RHcoopers's Avatar
RHcoopers
Just did a pulley install and had to remove thee motor mount bracket on passenger side
Old Feb 18, 2014 | 09:39 PM
RHcoopers's Avatar
RHcoopers
Just had to remove my motor mount bracket for a pulley install and when I reinstalled the brakes I tried torquing down the bolt to 74lbs as stated and the bolt seems to be stripped. It keeps threaded and doesn't get tighter. Should it thread this far down?
I'll try and get a photo but I keep getting this parse error notification.
Attached Thumbnails Front end bolt torque specs?-image-931958125.jpg   Front end bolt torque specs?-image-3656397931.jpg
boostedhaze
Jan 2, 2018 07:26 PM
silence2-38554
Nov 12, 2015 09:39 AM
gmonde
Sep 8, 2015 06:37 AM
FLYM1N1
Aug 15, 2015 11:20 AM
FatherG
11
Aug 7, 2015 07:49 PM
