tail light Help please
Old Jan 31, 2012 | 02:27 PM
motoballer21's Avatar
motoballer21
I have searched far and wide and even in this forum. I have clear tail lights on my 02 mini. I noticed my brake light is out and I wanted to replace it only to find that they are soldered into a bracket. Where can i purchase a new bracket of bulbs? Im new to the Mini community and would appreciate the help. thanks
Mirko
Old Jan 31, 2012 | 02:56 PM
dannyhavok's Avatar
dannyhavok
Are you sure it's soldered? Mine just pop out with a bit of a twist.
Old Jan 31, 2012 | 03:08 PM
motoballer21
yes im sure. I searched and saw that other people mentioned soldered tail light bulbs but i havent seen where I can buy replacements
Old Jan 31, 2012 | 03:10 PM
Capt_bj's Avatar
Capt_bj
I'm 99% sure there was no 'clear tail light' option on a 2002 there4 I suspect these are some E-Bay specials . . . the lights certainly DO twist out of a factory housing (reference Haynes chapter 12.8).
Are all the bulbs soldered in? Did someone do something wierd because the bulb was loose???? If not a full bead of solder all the way around, but something like a spot weld, you could possibly cut it away with a Dremel . . . or remove the solder if you have the tool/skill (this is doable) http://www.youtube.com/watch?v=hQFpYN2FPN0
Old Jan 31, 2012 | 03:13 PM
motoballer21
I was afraid that they were aftermarket. Seems to be spot soldered on either side of the bulb. May try and cut it away. The bulb plate says "Valeo" but I cant find any information on that company regarding mini tail lights.
Old Jan 31, 2012 | 03:42 PM
rkw's Avatar
rkw
Well, there's that remaining 1%...
MINI did make 2002-2004 OEM clear taillights, sold as a dealer accessory. They are probably still available.
http://realoem.com/bmw/showparts.do?...35&hg=63&fg=95
http://www.motoringfile.com/howto/white_lights.pdf
http://parts.miniofsouthatlanta.com/...120145835.html
You must replace the entire 3 bulb holder panel. I think the bulbs are soldered in to prevent people from replacing with clear bulbs (won't light up red).
Old Jan 31, 2012 | 03:55 PM
ACEkraut11's Avatar
ACEkraut11
How about a picture?
Old Jan 31, 2012 | 06:41 PM
rkw's Avatar
rkw
They are probably OEM. Buy replacements from any MINI dealer (they probably have to order it, which will take a few days).
RealOEM.com BMW R53 Cooper S White lights retrofit kit
Part number 63216919915 (item #2) list price $57
Here's an online source: http://www.penskeparts.com/DiagramsM...ts=63216919915
Some NAM vendors also sell OEM parts.
Old Jan 31, 2012 | 06:46 PM
dannyhavok's Avatar
dannyhavok
Interesting. My OEM tails say Valeo too, I assume MINI sourced them from Valeo. That seems like a terrible way to keep a bulb in.
Old Jan 31, 2012 | 09:45 PM
rkw's Avatar
rkw
It is the same bulb holder panel as in the standard taillights, but the bulbs are purposely soldered to prevent replacement. In a clear taillight, the bulb needs to light up red, but MINI is afraid you might replace with a white bulb. So they make the bulb non-replaceable and force you to buy the entire panel that has a red bulb preinstalled.
You can also buy the blank panel for the standard taillight and fit bulbs of your own choice.
Old Feb 11, 2012 | 11:52 PM
MFC's Avatar
MFC
if you're talking about the center brake light, there is no replacing the bulb. You will need to buy a whole assembly. Check ebay - it should be like $20. You may be able to find one on NAM as well.
Old Feb 19, 2012 | 12:43 PM
motoballer21
THANKS GUYS! Looks like this is what I have... I will order the parts soon. Sorry ive been MIA (just bought a new house and moved in) I do have some pictures of the bulbs.
Attached Thumbnails tail light Help please-valeo4.jpg   tail light Help please-valeo3.jpg   tail light Help please-valeo.jpg
Old Feb 19, 2012 | 01:15 PM
rkw's Avatar
rkw
The part number 63216919915 is confirmed in the 3rd photo (second line at the upper right, where it says MINI 63.21-6919915).
Old Feb 19, 2012 | 01:39 PM
motoballer21
Thanks again. I really appreciate your help! I ordered the part from Penske.
Old Feb 20, 2012 | 10:59 AM
drozd's Avatar
drozd
Why dont you just de solder it or dremel away the solder and put in another bulb
Old Oct 18, 2016 | 11:08 PM
BumbleBeeR50's Avatar
BumbleBeeR50
I can sell you two used circuit boards =D
Old Oct 20, 2016 | 07:51 AM
doomsdaybob's Avatar
doomsdaybob
I second what drzod and others have said, Dremel or file the solder blob down and all you'll need is a new bulb. I have several sets of tails and holders and they are all the same except for the solder blobs. If you have any experience w/ soldering you can always de-solder them as well.
Mb460
Aug 20, 2016 10:39 PM
smarsha11
Aug 24, 2015 06:03 AM
cm.d
Aug 19, 2015 08:51 AM
messyjesse96
Aug 12, 2015 05:51 AM
