Suspension What suspension is this?
Old Jan 29, 2012 | 11:17 AM
Yoda Mini's Avatar
Yoda Mini
I just bought my Mini a few weeks ago and I would like it to be a little lower so I removed the wheel to see what the set up was. I found these Koni yellows but what springs are these?
Also it appears these are NOT adjustable....correct?
So would these be coilovers but not adjustable coilovers?
Also the other day I was driving with the family in the car and my daughter (about 95lbs) was in the rear passenger seat and over hard bumps I could hear the wheel rubbing. I cant see any evidence of rubbing in the area but I did notice the spring is rubbing on the sway bar. How can I fix this?
maybe another 1/4 to 1/2" drop?
Old Jan 29, 2012 | 11:26 AM
Yoda Mini's Avatar
Yoda Mini
ok, it looks like I found some more info here.
http://www.dinancars.com/shop/D190-5...e-4-02-05.aspx
The Stage 2 Suspension for the MINI Cooper S adds an adjustable 19mm rear anti-roll bar to the springs, struts and shocks included in the Stage 1 system...
Performance Spring Set; Koni Adjustable Struts and Shocks; 19mm Adjustable Rear Anti-roll Bar.
Old Jan 29, 2012 | 09:45 PM
quikmni's Avatar
quikmni
I do not think that your adjustable rear sway bar has locating washers on the bar to help keep the bar from moving off to one side. So it could be that the bar has just moved to one side and you can push it back the other way to get it centered. Hopefully it is not bent.
You can try to move the bar with the car on the ground or with both rear wheels lifted up. If you just lift one side the bar will be loaded against the bushings and the bar will not move/slid in the bushings.
You can see in the link/picture of the Alta sway bar how it has locating washers on the bar, towards the bend. This locates the bar at the bushing mounts.
http://www.altaperformance.com/hardt...-rear-sway-bar
Old Jan 29, 2012 | 10:32 PM
Yoda Mini's Avatar
Yoda Mini
Interesting. Thanks I will check it out.
Old Jan 30, 2012 | 06:14 AM
blue2turbo's Avatar
blue2turbo
How low does the car sit? any chance you could get a full side profile picture? I am very interested to see the Dinan stance. Also, how does it ride with that setup?
Old Jan 30, 2012 | 06:36 AM
Helix13mini's Avatar
Helix13mini
You probably won't be able to slide the bar from side to side through the bushings without a long prybar, which will be challenging without a lift. Moreover, the swaybar will just move back to where it wants to sit, and smash into the spring. The problem is that the swaybar has the wrong shape and will never fit. I haven't seen that particular swaybar in our shop, but I have experienced bars that are ill fitting. There's nothing you can do but put a proper bar in the car.
vulkandino
Oct 31, 2015 08:29 PM
GAT
Oct 4, 2015 07:27 PM
Tires, Wheels & Brakes
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
Emnotek
Sep 29, 2015 07:37 AM
