R50/53 Need Alternator Removal Advice (2003 S)
Old Jan 26, 2012 | 06:20 AM
Doodarazumas's Avatar
Doodarazumas
My alternator has gone kaput, and last night I pulled the car apart to get at it. Everything went smoothly until it came time to unplug the alternator.
I can not for the life of me get the plastic plug (the three-wired one) next to the b-wire out of the alternator. Is there some sort of trick to it, or a tab of some sort that I couldnt' see? I just tried pulling on it, and I could feel it wiggle around, but I could never get it to actually come out. I even tried levering it out with a screwdriver, but all it did was bend the screwdriver.
Please tell me I'm missing something that will make this easy.
Old Jan 26, 2012 | 06:47 AM
Martin Brenneke's Avatar
Martin Brenneke
Ther has to be a little tab that pulls out or slides up or down that will allow the connector to pull apart. the Bentley manual shows that the connector comes apart by going down towards the ground. pictures are not that good in the manual. Check some other electrial connections and see how they work. Good luck.
Old Jan 26, 2012 | 07:04 AM
jasonsmf's Avatar
jasonsmf
I believe there is a little tab you squeeze to allow the plug to release. Squeeze and pull at the same time and it should come free.
Jason
Old Jan 26, 2012 | 07:23 AM
Doodarazumas
Thanks guys, got it out. You were right, the tab is on the top of the plug. For whatever reason it was wayyyy stiffer than all the other plugs on the car and I had to use a small pair of vicegrips to push down on it hard enough to pull the plug out, but once I did it came right out.
sevin
May 2, 2026 06:11 AM
bobbiemartin
Jan 20, 2016 05:28 PM
alistaircookie
Oct 8, 2015 10:52 AM
robbiedowns22
Aug 25, 2015 12:20 PM
greekzilla
Aug 23, 2015 03:44 PM
