R56 Ohlins suspension - Cost?
Old Jan 24, 2012 | 12:15 PM
ciscorob's Avatar
ciscorob
Has anyone purchased the Ohlins suspension components and if so where did you purchase them from and how much did it cost?
Old Jan 24, 2012 | 01:17 PM
Creeve's Avatar
Creeve
As far as I know they don't make anything for the r56. The r53 coilovers were $2800.
Old Jan 24, 2012 | 01:19 PM
ciscorob's Avatar
ciscorob
Yeah, they have stuff out for the R56 now, I was just looking to see if someone got a good price on them.
Those were just for your front coil-overs correct? I am doing both front and rear.
http://www.roadandtrackbyohlins.com/en/product-range/
I am hoping they are that cheap.
Old Jan 24, 2012 | 01:34 PM
Creeve's Avatar
Creeve
The link you posted shows both front and rear. I'm not aware of any company that sells fronts only. Any reason in particular you are looking at ohlins? Not alot of people run ohlins on these cars probably because you can get more for your money with cross or ast.
Old Jan 24, 2012 | 01:42 PM
ciscorob's Avatar
ciscorob
My experience with Ohlins has been extensive. I used them on my motorcycles for both street and track and hands down were the best option.
I don't look at "cost" as a factor when trying to put stuff on my car. I want it to:
1. Last
2. Be supported
3. Be of high quality
My girlfriend tried another "Comparable" setup on her BMW and while it was "ok" at best it still didn't have the same build quality as the Ohlins, didn't have the best support network for it and didn't have that "overall" feel I like about Ohlins. Hers were either far too stiff or too soft and neither of us were happy with them. Sold them on Ebay, bought Ohlins and a few days of tweaking here and there and we love it.
Old Jan 24, 2012 | 01:57 PM
andyroo's Avatar
andyroo
Ohlins is in a completely different world than Cross.
AST 4100 is close, but the real comparison would be the 5000 series, which are likely more expensive.
Most people don't run Ohlins on this car because they're a bit more expensive than they want to pay. Honestly, that's why I don't run them. I'd love to but just can't.
To the OP, I can check with an Ohlins dealer for you if you like.
- Andrew
Old Jan 24, 2012 | 02:12 PM
ciscorob's Avatar
ciscorob
Yeah, I need pricing to see when I can get these on the car.
Old Jan 25, 2012 | 09:23 AM
Creeve's Avatar
Creeve
AST 5100 are $3k, so are the KW clubsports. Both offer top mounts which the ohlins do not. Ohlins warranty is only 2 yrs, kw is lifetime. Its your money, you should definitely buy what makes you happy, but for my money I'd be looking in a different direction.
Old Jan 25, 2012 | 09:26 AM
ciscorob's Avatar
ciscorob
Lifetime against what though? I highly doubt they are going to warranty a leak from wear and tear on a 5 year old purchase...perhaps if something major breaks but I don't see it happening. I had Ohlins front forks on bikes that lasted over 5 years without a rebuild under harsh conditions.
The Ohlins offer an overall great ride and great tuning ability. I've tried a lot of other things in the past and Ohlins seems to meet my demand for a smooth ride for an everyday driver and handling well when dialed in correctly for the track.
Old Jan 25, 2012 | 09:27 AM
ciscorob's Avatar
ciscorob
Where do you see the benefit for the top mount though from the other kits with the R56? I am wondering why they didn't offer it; however, I haven't torn apart this car yet since it is only 3 months old.
Old Jan 25, 2012 | 10:29 AM
Creeve's Avatar
Creeve
Well I guess to be fair the ASTs are offered through Vorshlag with their top mounts. They are sold separately so they could just as easily be put on the ohlins. The factory top mounts are just stamped sheet metal pieces with rubber bushings. The Vorshlags are laser cut plate with spherical bushings: http://www.vorshlag.com/product_info...roducts_id=481
They are just stronger, allow for less deflection/play in the system. Plus they are what provide camber adjustment in the front.
Old Jan 25, 2012 | 01:59 PM
andyroo's Avatar
andyroo
Actually, AST 5100 are $3k....not including springs or topmounts. So you're looking at well over 3500 when it's all said and done.
Ohlins are worth it. The quality of the damping is very, very good. I do also like AST and KW.
MSRP is $2839 for the Ohlins.
- drew
Old Jan 25, 2012 | 04:49 PM
modernbeat's Avatar
modernbeat
...he Vorshlags are laser cut plate with spherical bushings: http://www.vorshlag.com/product_info...roducts_id=481
And THAT is the important part. The MINIs have a LOT of deflection and side loading to their rear shocks. That's one AST spec an inverted shock for the rear. It's stronger. But the OEM top mount also adds some side loading and we highly recommend getting the spherical mount. It makes the wiper and piston seals last a lot longer and extends the period between rebuilds.
Old Jan 26, 2012 | 06:02 AM
Creeve's Avatar
Creeve
- drew
Yea, I just realized that. Tried to clear it up in the post above.
Old Jan 27, 2012 | 07:23 AM
richardsperry's Avatar
richardsperry
Is Ohlins good, yes. Is it worth it to most people? Not a chance.
Most people can't drive out of a paper bag, let alone detect any difference between shock absorber brands.
Old Jan 27, 2012 | 08:15 AM
andyroo's Avatar
andyroo
Agreed that Ohlins are not for most people simply because they're overkill and expensive, but there's still no reason to run crappy shocks. I run the best shocks I can afford (not including motorsports shocks), which sadly just means Koni Yellows.
Crappy shocks should be avoided by all means IMO. There is a big difference to feel even on the street.
- Andrew
Old Jan 27, 2012 | 08:25 AM
richardsperry
I'm very happy with the Koni yellows and TSW springs.
Old Jan 27, 2012 | 08:27 AM
andyroo's Avatar
andyroo
I really like my Konis too. Great shock for the money.
- Andrew
Old Jan 28, 2012 | 08:14 AM
ficcion's Avatar
ficcion
How is this for timing, enjoy: https://www.northamericanmotoring.co...n-the-r56.html
iclancy82
Jan 2, 2021 08:59 PM
ej
Nov 17, 2015 09:21 PM
Suspension Products
Sep 10, 2015 11:46 AM
mikeson
Sep 6, 2015 06:21 AM
Suspension Products
Sep 3, 2015 09:41 AM
