R58 Xenon headlights
Xenon headlights
HI y'all. I have the R58 with the factory Xenon headlights. Will it harm the lights if I run it in Auto with the daytime running lamp (DRL) or should I disable them? The reason I ask is I own a Passat and it was no-no to run DRL because it runs at a lower power level.
IIRC (in the Passat), it needs a certain power level (when headlights are turned on manually) and DRL's run at lower power and hence is not good with Xenon headlights. This was true with my 2002 VW Passat, so I was wondering if the same applies to the R58. I suspect the DRL's run at the same power level as if the headlights were turned on.
The car will not run the headlight at a reduced power like similar DRL in halogens because like you already said they are made ot do that. Thus the factory will not try to only push say 9V to the HIDs instead of the required 12. No worries to run DRL if it makes you feel better.
I like having DRL's, but for some reason, MINI has programmed the DRL's to also light up the taillights & marker lights on the Coupé, which is a waste. So I shut them off.
Unless you've rewired your fog lights, they won't come on unless the headlights are on. At least, that's what I've found on my R58.
http://www.realoem.com/bmw/showparts...68&hg=63&fg=05
That was nice of him, I beleive we have the same MA
gar56
Nov 15, 2016 06:41 AM
vulkandino
Oct 31, 2015 08:29 PM
Sep 29, 2015 12:17 PM
Sep 29, 2015 12:16 PM
Sep 29, 2015 12:11 PM
