R56 Running a bit rich?
Running a bit rich?
Nothing I'm too worried about but it leads up to my question.
I have an '09 JCW with low mileage, running a stage I alta tune. When I had my riss racing catless downpipe on the car, it seemed i was running very rich. I know that not having a cat increases smell/sight of exhuast, but i was wondering....
....does the readings of the O2 sensors effect how the ecu adjusts AFR?
That voltage is interpreted by the ECU, and the impulse length of the fuel injectors are adjusted accordingly.
The post-cat oxygen sensor is checking the efficiency of the catalyst.
When you didn't have a catalyst installed, you were smelling unburned hydro-carbons and sulphides.
- Erik
The post-cat only checks the sanity of the catalyst; nothing more.
- Erik
Kimolaoha
Dec 5, 2020 09:32 PM
imanexcellentdriver
Aug 31, 2015 08:08 PM
Drivetrain Won't hold idle after work performed
Lt. Dan
Aug 10, 2015 08:23 AM
