R56 Heater Low Coolant
Old Jan 21, 2012 | 04:05 PM
MGoode212's Avatar
MGoode212
Heater Low Coolant
I have noticed recently that when I'm at a stop light or sitting at idle the temp of the heater cools off. I checked the coolant level in the reserve and it is low and needs refilling. Can I simply add more antifreeze to the reserve tank or do I need to bleed the system or take it to the dealer to do this?
Old Jan 21, 2012 | 04:55 PM
drsimmons's Avatar
drsimmons
Is it bone dry???? To answer your question though, yes, you can add coolant but be sure it's the correct type (blue from Mini or Zerox Z05). Try filling it to level and recheck in a day. If you are losing coolant still you may have a thermostat/housing leaking. Have dealer check for you. When mine was leaking I couldn't find a puddle but it was accumulating under the engine pan. It's about $450 if they do it.
shorenetworks
Nov 4, 2019 06:18 PM
jef1f
Sep 18, 2015 02:49 PM
OdzBodkinz
Sep 11, 2015 07:20 PM
Gen1Parts
Sep 7, 2015 01:37 PM
