Off-Topic :: Autos Interested in discussing other autos? This is the place!
car paint question
Old Jan 20, 2012 | 04:04 AM
condor27596's Avatar
condor27596
car paint question
My friend who Knows Stuff says 1 qt of base/clear is enough
to paint my car. Of course the paint place says I need a gallon.
That is a big discrepancy.
I want to order 2 quarts each of base and clear.
Is that enough to paint my car and give me a little buffer to not
run out? It's a disaster to start and run out.
My budget is not unlimited and 2 qt is obviously half of a gallon.
Also, I do not understand this idea of sealing the primer.
I was thinking 2 part urethane primer was enough.
I plan to buy the house paint from here www.tcpglobal.com
I have painted before but this is the first time of base/clear with
an hvlp gun so I really do not have a feel for how much is needed.
2 qts seems plenty I painted before with acrylic enamel which came
out like a firehose and used 3/4 gallon but I have to be sure.
I will be painting an 87 CRX, which is basically half the size of a normal car.
Old Jan 22, 2012 | 01:02 PM
masternut's Avatar
masternut
It is better to have too much than not enough
Old Jan 23, 2012 | 11:30 AM
condor27596
I've decided to buy two quarts.
I'll spray until I run out or finish.
The main thing is to not have to explain to the wife why I spent
$600 on paint when I only needed to spend $300.
Old Feb 7, 2012 | 03:57 PM
ColinMc's Avatar
ColinMc
I painted my entire car, door jams and everything and used just over 1 qt of basecoat...but again different brands of paint reduce differently.
I got just over a half gallon sprayable of basecoat out of just over a qt of color. 1:1 ratio.
Coverage plays a role too...different colors cover better/worse...etc etc. There are a lot of variables. But a Gallon of ANY line of paint, even economy basecoat is way way way too much for a Mini lol.
EDIT: Just saw you are doing a CRX...sorry misread. But yeah my logic still stands. Small car, 2 qts will be plenty! My 95 Taurus SHO when I did a color change on that, I didn't even use a gallon of basecoat, and i did EVERYTHING!!! Door jams, bottom of the hood, firewall, even inside the trunk.
Alkaidovich
Jan 30, 2021 01:35 AM
silence2-38554
Nov 12, 2015 09:39 AM
chicohuahua
22
Aug 20, 2015 11:17 AM
nomar116
Aug 10, 2015 11:24 PM
Dashdog
Aug 10, 2015 06:17 AM
