R56 My windshield is heavily pitted, repair/replace??
Old Jan 18, 2012 | 10:17 AM
Minifan07's Avatar
Minifan07
Is it worth it even to replace? I'm assuming that the problem will repeat itself based on the sharp angle of it.
Old Jan 18, 2012 | 10:58 AM
MINIdave's Avatar
MINIdave
It will become pitted again, yes. But the clarity you'll enjoy in the meantime is well worth it. You don't realize how bad it's gotten till you get the new one!
I have $100 deductible on my insurance, so I get a new one every two or three years.....
Old Jan 18, 2012 | 12:13 PM
Minifan07's Avatar
Minifan07
Guess I'll do the same, thanks for the tip.
Old Jan 18, 2012 | 12:22 PM
mrx19's Avatar
mrx19
Replacement is the only real solution. In the short term, try a couple of applications of RAIN-X. Seems to help.
Old Jan 18, 2012 | 01:49 PM
buzzsaw's Avatar
buzzsaw
May consider this when it comes time: http://www.clearplex.com/
Old Jan 19, 2012 | 01:24 PM
Scott Auld's Avatar
Scott Auld
Florida has a mandatory zero-deductable on windshields
Old Feb 13, 2012 | 08:53 AM
mikeyb74's Avatar
mikeyb74
I was looking into clearplex when I replaced my BMW E46's windshield. The problem I was running into was that no local glass shop installs this product.
I'm in need of a windshield replacement.
Old Feb 13, 2012 | 09:19 AM
Bubble and Squeak's Avatar
Bubble and Squeak
Funny all the things it says it does are all things the window does already. UP Protection, YEP. Protect family from failure, YEP. No film is going to really protect your glass from a rock at a 120 mph (the speed of the rock to you, and you to the rock).
I have a zero deductible. My 2008 Altima is on its 3rd, 04 XTerra on the 3rd, and when I had my 99 Beetle, 5th. Just comes with 25k miles a year.
Old Feb 13, 2012 | 09:27 AM
Minibeagle's Avatar
Minibeagle
Imma take the windshield out and get goggles for myself and passenger(s) instead
Old Feb 13, 2012 | 09:30 AM
mikeyb74's Avatar
mikeyb74
tailgating? j/k
I do the same mileage as well. My 03 Altima had windshield replacement every year of ownership. 2005 to 2012.
Old Feb 13, 2012 | 09:34 AM
AustinS's Avatar
AustinS
I wonder...is it the angle, or is the glass soft? No matter that it is as clean as possible, when I drive into the sun, at certain angles, mine is so pitted it is unbelievable. Oh BTW, I have 39,000 miles on it.
Old Feb 13, 2012 | 10:12 AM
Minibeagle's Avatar
Minibeagle
Doesn't replacing your windshield over and over on your insurance make your premiums increase?
Old Feb 13, 2012 | 11:21 AM
mikeyb74's Avatar
mikeyb74
I think its a combo of the angle and soft glass. I have 38K on MCS.
I didn't but I waited for it have an actual crack in it before claiming it.
Old Feb 13, 2012 | 11:30 AM
daflake's Avatar
daflake
Comprehensive claims don't generally increase your premium but this really depends on the state you live in.
Old Feb 14, 2012 | 06:30 AM
richardsperry's Avatar
richardsperry
Just a couple of points...
No rock is going to be coming at you at 60mph, unless someone shoots it at you. So 120Mph closing rate isn't very likely. Usually rocks fall of trucks or trailers, bounce around, get your attention, then you sit there pretty hopeless as you watch it bounce and then smash into the windshield or some other part of your car.
Multiple comp claims will eventually make your rates go up.
Yes, combination of vertical angle, and lots of crap on the roads.
Old Feb 14, 2012 | 07:54 AM
daflake's Avatar
daflake
Really does depend on your state. In Mass you could get two windshields per year I believe and your rates could not be raised.
Not sure about MD as I haven't really checked but there are other states in which comp claims won't affect your rates.
Old Feb 14, 2012 | 08:24 AM
Mini2na's Avatar
Mini2na
Not sure that it matters, (or even correct) but the glass man I spoke to said the MINI glass is hard... brittle. So combined with the steep angle of the windshield they are going to get pits.
Mine is full of them too.
Old Feb 14, 2012 | 09:52 AM
davisflyer's Avatar
davisflyer
What brand windows are you guys going with? Stock Mini or aftermarket?
Old Feb 14, 2012 | 12:23 PM
daflake's Avatar
daflake
If you go aftermarket, get PPG glass. It is pretty much the same that MINI uses. I have found that the other glass is crappy. I had them remove two of them due to warped fields in the glass. Only the PPG was good to go.
bahman
Feb 14, 2016 10:29 AM
IrishMCS
Dec 1, 2015 04:21 PM
aldito2
Sep 30, 2015 10:44 AM
The Rossness
Sep 17, 2015 03:06 PM
Panik
Sep 9, 2015 08:36 AM
