Hope this helps others with hissing aux sound
Old Jan 11, 2012 | 01:23 PM
ayk07's Avatar
ayk07
looks like bmw and mini's are having hissing problems with iphone 4s when the volume is turned up. i am having that problem and just ordered http://www.amazon.com/FiiO-L3-Line-C...6316627&sr=8-1 to fix that problem. the problem seems to be that when connecting an aux cable through the headphone jack on an iphone 4s it messes with the mini's stereo somehow.
here is a long thread on a apple forum with a bunch of people having the same issue and they fixed it with LOD cable mentioned above. i tried my droid phones with the old aux cable and everything is perfect. seems to be a problem with the iphone 4s.https://discussions.apple.com/thread...rt=15&tstart=0
Old Jun 12, 2012 | 12:34 PM
scottt's Avatar
scottt
If we use the cable you recommend, we won't be able to charge the phone, correct?
Old Jun 12, 2012 | 01:16 PM
Mojito's Avatar
Mojito
or use any of the Connected features
why MINI needs a cable with both usb and aux is beyond me. But it won't work with just the usb cord. Plenty of other manufacturers are able to do this without the need for the aux cable
Old May 19, 2013 | 12:37 AM
retrogrouch's Avatar
retrogrouch
If you used the USB/Aux Y cable plus a USB charger plug in the cigarette lighter, would that work to still run a clean audio signal to the aux jack and get a charge off the lighter? Or would the fact that the usb is hooked up cause the phone to think audio has to come out of usb rather than aux?
Old May 20, 2013 | 09:14 AM
scottt's Avatar
scottt
Yes, I have a USB cigarette lighter charger. I can charge the phone, and listen via the Aux port. Works great for Pandora and (at the same time) my Siri driving directions.
Old May 20, 2013 | 11:01 AM
retrogrouch
Awesome! Great to hear!
Old Jun 4, 2013 | 10:25 PM
retrogrouch
Just confirming that it indeed works! Got my Y cable yesterday and hooked up my iphone 3GS to the AUX plug and a cig USB. Now all I need to do is swap channels. I plan on using this pre-made plug by www.newministuff.com. Its certainly a bit of money compared to swapping pins myself, but since the car is a lease, I figured I'd use an easy plug and play, less invasive solution:
http://www.newministuff.com/new/shop...uctshow&id=745
Old Jul 29, 2013 | 05:34 AM
SchHDogs's Avatar
SchHDogs
I do not have this problem with my iPhone 5, but my son has this issue using his iPad 2 in the car, even though he is not charging the device via USB at the time. For $9.99, might be worth a try. Thanks,
W0TM8
Dec 19, 2019 07:50 AM
surfblue
Oct 24, 2018 01:20 AM
David.R53
Sep 1, 2015 06:49 PM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
quickquest88
Aug 8, 2015 08:45 PM
