Blue liquid leaking onto driveway under engine compartment
Old Jan 7, 2012 | 04:50 PM
quickslvr580's Avatar
quickslvr580
Hi,
Does anyone happen to know what the blue liquid leaking from under my engine compartment could be?
I know it's def. not coolant.
Thanks for your help.
Old Jan 7, 2012 | 05:32 PM
quickslvr580
Actually I stand corrected; I think it is coolant from the way it was running off the paper I laid down. It wasn't viscous. I was just surprised because I always thought coolant was green.
Anyway, it must be a bad thermostat housing.
I'll get it checked this week.
Old Jan 7, 2012 | 07:02 PM
ZippyNH's Avatar
ZippyNH
Bmw mini coolant is blue...
you are likely overdue to get it changed...it is not longlife, and not the same as yellow/green...similar, but not the same.
Old Jan 7, 2012 | 07:05 PM
ZippyNH's Avatar
ZippyNH
Most common places to leak on a s gen1 is thermostat, and the coolant tank.
They tend to split/leak at the seam..
Easy diy if it is the coolant tank on the s.
Old Jan 8, 2012 | 07:37 AM
JDCmini's Avatar
JDCmini
Mine was the thermostat housing.
Old Jan 8, 2012 | 07:52 AM
daflake's Avatar
daflake
Originally Posted by quickslvr580
Hi,
What side is the leak and what year is your MINI? Could be engine mount.
Old Mar 16, 2012 | 08:18 PM
quickslvr580
Late update... but I ended up changing the Thermostat Gasket and Housing. It took me about an hour or so to do the replacement and then another half hour to re-fill coolant and bleed system.
Thanks for the input.
Old Mar 16, 2012 | 09:24 PM
bahawton's Avatar
bahawton
Mini replaced my thermostat housing when mine leaked due to a TSB on the subject. They did it for free right before my warranty expired.
alistaircookie
Oct 8, 2015 10:52 AM
ShadyCoop
Aug 24, 2015 06:05 AM
elightbo
Aug 17, 2015 01:50 PM
Powershift
Aug 16, 2015 05:14 PM
