R56 Can someone show me to the cheapest source for a BSH Catch Can kit?
http://www.waymotorworks.com/bsh-oil-catch-can-r56.html
http://www.detroittuned.com/shop/?productID=494
one of those two. whichever has better shipping is the deciding factor. plus it's good to support one of these guys
From your sig description Minifan07, I assume you have an 07 MCS. If so, Sku# r56bshcc for oil catch can and Sku# bshboosttap for boost tap from www.waymotorworks.com.
Normally has great prices or at least as good as anyone plus Way will service you well. He's very knowledgable and will answer any questions you have.
Bigprfed22.....Got a question, probably stupid question but I'll ask you anyways.
What would happen (damage, etc.) if one forgot to check OCC and it fills up totally? Spill out to the turbo??
Haven't done it yet but just wondering.
Mayyyyybe under high G conditions, but realistically the can will be full so it will not catch any more, in that case the pcv gases will not condense thus it will be like it isnt there.
Thanks. Down here in lower Alabama due to the temp extremes, 38 one morning and 55 next I tend to get more water condensation so I've been checking every week. Check the oil and coolant at the same time.
Yeah any cold temps will make you think your getting more gunk but its just water condensation. I am running open pcv because i wanted to ensure no gunk got in anymore period... there goes my carbon footprint lol.
The boost tap by the way has a plug in the end to stop flow as well as 2 plugs which can be removed for vacuum gauge addition. Don't know much about that part just know that both parts work. I use a 1 inch wide syringe with a 1/4 inch hose to pull out the crud from the dip stick holerather than draining from the lower hole on the catch can. Makes it alot faster and cleaner.
Aug 19, 2015 12:51 PM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
M7Speed
Aug 6, 2015 01:48 PM
Coke cans come baffled?
