R56 Are 2011+ Harman/Kardon systems lower quality?
As some of you saw from my other thread, I've recently upgraded from a 2010 MCS to a 2011 JCW. Both have the H/K system.
I can definitely say the JCW sounds worse. The mids are severely lacking, the bass is grossly exaggerated, and quiet sounds are far quieter than they should be. I can live with poor EQ, but the last point is driving me nuts.
For example, on the intro to AC/DC's Back in Black, Malcolm Young's pulloffs after the main riff are quieter than the lead guitar. On my old MCS, these notes were audible but softer. On my JCW, they are almost inaudible, as in you cannot hear them unless you listen very carefully for them.
Did MINI change anything between 2010 and 2011 on their sound systems? It's driving me nuts, and I know I'm not going crazy, as my brother noticed the same thing.
I haven't listened to Back in Black on my HK so I can't comment on that, but I'm not very impressed with the HK system. You're right about the midrange and the bass. The reason I ordered it is because I had read a lot of threads saying that the standard stereo was awful. They really should put an excellent upgraded sound system in this car because it's so difficult to improve on it given the limited space in the car for the components. It seems like, short of a rear seat delete, the only way to mount a woofer is to essentially sacrifice the little bit of boot space you have.
I've checked realoem.com and looked at the part numbers. The speakers all have the same part numbers since the inception of the harmon kardon system in 09. The one thing that has changed over time is the amplifier, so I suspect that is where your issue lies. Here is what realoem.com says.
amplifier
up to 08/2010 651292178877
09/2009 to 08/2011 65129239601
09/2009 65129253890
So it appears that there are three different amplifier part numbers some being used at the same times. So it is possible you notice a difference, but typically the amp is not what you'll hear major differences from.
amplifier
09/2009 65129253890
I really like my H/K. I had a 2009 with the regular radio and I think my 2012's H/K is a huge improvement...but not a fantastic system. I have a few audiophile friends who can help me tweak it. I got $2250 off of my car...so I always think of it as "I got free H/K system ($750), Sunroofs ($1000), and auto A/C ($500.)" lol
I think this has been discussed a lot, but the H/K system seems to be "better" than stock but just adequate as a factory upgrade. IMO the stock system was pretty crummy. MINI could have done much better but I don't have any real complaints. I think someday if I add a subwoofer to my H/K, it will be "perfect" for me. It is interesting that the amp part number changed recently.
Man, I don't need any more WOOF! I have to turn down Molly's bass to at least -5, and turn up her treble to at least +5 to get something close to natural sound reproduction ("natural," as compared to the relatively neutral sound of my home stereo, with a mix of old Advents, Cambridge, plus Polk subwoofers)
It is funny that the reactions here about the quality of the Mini's sound system are all over the place. This is consistant with my own experience. I have had 3 Minis all with the base sound system. The '04's system sounds good, with all the settings at 0. The '07's system was much worse; mostly lacking bass. The '12's system is probably the best of all (all settings at 0, and not overloaded with bass), which may be due in part to the Sirius and HD option that they now give you. I would think that if someone isn't hearing mids, then I would look at the speakers. Even though the part numbers are the same, the speaker to speaker quality may not be there. As for too much bass, that might be in the amp. If these amps are programable (alexs3d2 said something about software changes) could these systems be tweaked by the NCS Expert?
oldsbear - The old Advents, ARs, etc are fantastic examples of the way sound should be reproduced. However, it is tough to compare a car's system to their quality, but I understand about trying to match what you are used to.
How did you manage to get $2250 off MSRP?
My HK system sounds perfect. Everything set at zero. Differing music sounds different of course but not so much that I have to change any bass/treble settings.
For instance Pink Floyd's "Dark Side Of The Moon" on a Mobile Fidelity Sound Lab Ultradisc needs to have the volume decreased just a pinch as compared to say Giant's "Last Of The Runaways", which needs the volume tweaked up a bit higher. Both still with flat Bass and Treble. However when I put on Shawn Colvin's "Whole New You", This CD takes an even different tweak. The only CD that I have found that I have to turn down the Bass is on the Don Dorsey Telarc CD called Bachbusters. This CD is guaranteed to blow most systems unless you take evasive actions before tuning up the disc. It's a pretty cool disc that will blow you away listening on a great sound system.
I listen to all flat audio at home through a Yamaha Amp system with M&K Speakers. (Who I understand went belly up. Too bad they built great speakers and subs. I will have to replace them someday but for now they rock.)
So I am pretty happy with the sound system. Much, much, much better than my 09 MCS system.
Ok. So I have a MINI on order right now. It's my third car from Brian Harris MINI and they do not budge on prices. I did manage to get a few accessories from them. Do you think I did bad? I basically only got these bc my girlfriend is ordering a mini convertible for over 30 grand. and I used that against them. What's the 500 you-ification?driving lamps
rubber mats front back and trunk
lets motor chrome frame
Ok. So I have a MINI on order right now. It's my third car from Brian Harris MINI and they do not budge on prices. I did manage to get a few accessories from them. Do you think I did bad? I basically only got these bc my girlfriend is ordering a mini convertible for over 30 grand. and I used that against them.Thread
minicoclub
Nov 11, 2015 07:25 AM
Aug 19, 2015 12:51 PM
Aug 12, 2015 01:24 PM
