Suspension Adjustability of stock suspension?
Old Dec 28, 2011 | 10:22 PM
Purie's Avatar
Purie
How adjustable is the stock suspension for dailing in camber, caster, and toe?
It looks like -1.5 camber all the way around, 0 toe and maxed caster is the norm. Will I be able to get there with what I got.
Any tips or suggestions would be helpful as I want to get a proper alingment done before I start messing with everything.
Cheers
Old Dec 29, 2011 | 12:40 PM
andyroo's Avatar
andyroo
Rear camber has a little adjustment...if you're at stock ride height -1.5 rear should be doable.
Front camber is not adjustable. There is a pin that you can remove to get another 0.5 degrees up front but i think you'll max out around 0.9. Do a search for the "free camber mod."
Toe is adjustable front and rear and 0 toe isn't a problem.
- drew
Old Dec 31, 2011 | 05:31 AM
Purie's Avatar
Purie
- drew
Thanks for the tip, gonna have a search for it now. So if I want more then -.9 camber I'll need some camber plates huh?
Old Dec 31, 2011 | 10:46 AM
andyroo's Avatar
andyroo
yup. I like the ireland engineering fixed plates on my 1st gen...still rubber for a smoother ride. You should end up around -1.7 up front with them (not 100% sure for a 2nd gen). Adjustable plates do the job if you want lots of camber but most will be a little harsher than stock.
- drew
Old Dec 31, 2011 | 11:20 AM
Eddie07S's Avatar
Eddie07S
Actually, the R56 front camber is adjustable to only about -0.6 deg (had it measured). Here is a good link:
https://www.northamericanmotoring.co...ustment-2.html
See post 44
IE fix plate is "advertised" to give -1.2 on the R56. That, plus the -0.3 the factory allows for -1.5. My '07 was measured at -1.6 with the IE plates...And they are fantastic on the Gen 2s. Only a slight change in ride quality.
Old Jan 1, 2012 | 09:28 PM
DOC4444's Avatar
DOC4444
I got -1.4 degrees (max) in front with pins removed, IE fixed plates, stock Justa springs and Bilstein HDs. I assume with an "S" with lower ride height or otherwise shorter springs, you should be able to get a little more negative due to lower ride height. With the alignment in my sig, I have 15K miles on my tires and have perfectly even wear, rotating every 3K miles.
DOC
Old Jan 2, 2012 | 02:55 PM
Purie's Avatar
Purie
That plastic pin trick looks nice and easy, but does it really move you out of the d-stock class? I was planning on doing a event or two based around that class before I go all out on suspension.
Old Jan 2, 2012 | 07:42 PM
honda93's Avatar
honda93
Perfectly legal for Stock.
Old Jul 31, 2012 | 05:48 PM
k_h_d's Avatar
k_h_d
Resurrecting an old thread here... Is this a safe and permanent modification that can be done? Will there be any appreciable gain in handling for autocross?
Old Jul 31, 2012 | 06:58 PM
Purie's Avatar
Purie
It's totally safe and 100% reversible, you'll just have to get another set of those plastic pins. I posted more info on the other thread on handling benefits for ya.
Old Jul 31, 2012 | 08:23 PM
Eddie07S's Avatar
Eddie07S
Need to realign for toe in though...
Kimolaoha
Dec 5, 2020 09:32 PM
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
Emnotek
Aug 13, 2015 05:47 PM
Minibeagle
Aug 13, 2015 10:00 AM
