What to do with peeling clearcoat on these wheel lips?
Old Dec 28, 2011 | 03:45 PM
atikovi's Avatar
atikovi
These are stock 17 inch wheels and all four are like this. If I remove the center section can I put the wheels in a bead blaster to clean off that mess from the lip? Then what? They have a machine finish but I can't duplicate that. Should I just paint them a bright silver?
Old Dec 29, 2011 | 06:33 PM
hunter99's Avatar
hunter99
Why not use a wheel repair shop to fix them? They usually are pretty reasonable and would save you the hassle of dealing with it. Plus, the lip would keep the machine finish over a painted one.
Anyway, just a thought to check out.
Old Dec 29, 2011 | 06:55 PM
atikovi's Avatar
atikovi
One place I called quoted me $150 each. I ain't paying $600 for someone to paint the 1 inch lip on the wheels. I'll deal with the hassle and spray it myself to save nearly $600. I doubt most wheel repair shops can redo a machine finish anyway since the wheel has to be machined on a lathe.
Old Dec 29, 2011 | 07:14 PM
kapps's Avatar
kapps
As long as a shop had a lathe big enough to chuck those wheels, it would be a very quick job to run some scotchbrite by hand along the bad surface to remove the paint and leave the aluminum with a nice machined-like finish.
Old Dec 30, 2011 | 07:04 AM
bluefox280's Avatar
bluefox280
Yes, separating the wheel face from the barrel will allow you to easily clean / media blast the barrel to remove the oxidation.
What finish do you want? Are you wanting the OEM 'brushed' look?
Polishing them would be the simplest, brushed isn't difficult if you obtain the right tools.
That's completely up to you.
A bare metal polish is the easiest to keep clean and touch-up if there's small scratches after the wheel has been reassembled.
- Erik
dyeLucky
Sep 11, 2015 10:41 AM
mini4mo
Aug 25, 2015 08:00 AM
Overpolished
Detailing 101
15
Aug 21, 2015 07:19 PM
vicj
Aug 13, 2015 10:46 AM
dyeLucky
Aug 7, 2015 07:10 AM
