R57 New to Me 2010 R57 MCSC Questions
Old Dec 11, 2011 | 03:47 PM
LarriB's Avatar
LarriB
I just got my car on Friday with 17,000 miles. I have a coupe of questions.
1-When the top goes up, the motor really sounds lie it's straining. There a lot of whining going on. Is this normal?
2-I get a slight clunking from the driver's side doorjamb over city bumps. Is tho normal?
3-There's a vertical streak of grease in the middle of my driver's side window. I assume the dealer can dissemble the door and clean up the grease.
4-I can lower my top from the comfort access remote. Can one set the remote to raise the top?
5-And tonight the Tire Pressure Warning went on. (Yellow Triangle with an exclamation, correct?) I had the tires rotated today and a nail removed. I reset the warning, and it seemed to disappear off the tachometer area, but as I shut down the car I noticed on the Speedometer. I guess I'll check the tire pressures tomorrow, but presuming they're correct, is there some other calibration?
Thanks,
Larry
Old Dec 14, 2011 | 09:50 AM
Mad TKD's Avatar
Mad TKD
Yes what you are describing is normal
I really dont know about that one. Its kinda hard to really understand how it sounds from just your description
If that is so then yes the dealer should be able to take the panel off and replace the door seal. I have seen that happen in other cars too and most likely the plastic door seal has fallen down in the door some how. Its a easy fix.
Raising the top is the same way but just push and hold the lock button
It should go off if all the tire pressures are over 32 psi I think.
Thanks,
Your welcome
Larry
David
Old Dec 14, 2011 | 11:36 AM
LarriB's Avatar
LarriB
And Thanks!
Philipangoo
Sep 16, 2015 11:54 AM
Aug 28, 2015 12:56 PM
Aug 28, 2015 12:50 PM
jziran
Aug 24, 2015 04:50 PM
blackie
Aug 23, 2015 08:44 PM
