Will 18 inchers from a 135i fit?
Old Dec 9, 2011 | 08:44 AM
FredoinSF's Avatar
FredoinSF
I found a nearly new set of 135i 18 inch wheels for sale. Anyone know if they will mount on a CM without adverse effect or would I need spacers?
Thanks in advance for feedback.
Old Dec 18, 2011 | 05:40 PM
mellowmcs's Avatar
mellowmcs
I was looking for similar information
I plan on getting 1 series rims that are: 7.5x18 ET:49
stock 7.5 x 18 is ET52so it's only a difference of 3mm. This should be fine IMO but I plan on doing a test fit with a friends 135i front wheels.
Old Dec 18, 2011 | 06:43 PM
niquemarshall's Avatar
niquemarshall
Well the BMW has a five lug pattern and the mini only a 4 lug..
Old Dec 18, 2011 | 06:44 PM
niquemarshall
Ooops that's a countryman! Derp.
Old Dec 19, 2011 | 01:41 PM
mikeyb74's Avatar
mikeyb74
They should fit. I've seen afew CMs with 17s and 18s from an e46.
Old Dec 23, 2011 | 02:53 AM
hor_fun's Avatar
hor_fun
yes they will. you can go to a max offset of +35. but im not too sure if there will be rubbing issues if your r60 is lowered.
im waiting for my NM engineering springs to arrive 1st. then next will be wheels!!!
Old Dec 23, 2011 | 07:30 PM
youthanasia's Avatar
youthanasia
I'm on +35 17x8 BMW rims for winter tires. No rubbing with stock sport suspension with 225 wide tires.
Old Jan 1, 2012 | 04:10 PM
mellowmcs's Avatar
mellowmcs
I test fit my friend stock 18x7.5" 5 spoke 135i wheel and.... it fits but there is only about 2mm or less of clearance between the brake caliper and the wheel spoke so looks like it'll need about 3-5mm wheel spacer to make it fit properly. :(
Old Jan 10, 2012 | 04:26 PM
minie's Avatar
minie
anyone have picture of there setup?
trw92a
Aug 26, 2015 01:47 PM
Aug 25, 2015 07:11 AM
Aug 19, 2015 12:51 PM
Aug 12, 2015 01:24 PM
