R50/53 TPMS question
Old Dec 4, 2011 | 08:24 PM
jpitchford's Avatar
jpitchford
TPMS question
I just bought my 02 Cooper the low tire light was on when i bought the car but the left rear looked low so i didn't think much about it. She needed tires anyways and the price for the car was right. Now after putting new tires on I keep having to reset the light but non of the tires are losing air. When i swapped one the new tires i noticed the were so sensors on the wheels. I figured that was the reason the light was on. I have been looking for sensors and just read that my mini uses the ABS sensor to determine tire pressure. If this is actually the case as i looking at a need to replace a wheel speed sensor? Why hasn't my car turned on an ABS light as well? I might hook up my scanner to see if there is anything funny showing up. Thanks
Old Dec 4, 2011 | 08:35 PM
Fly'n Brick's Avatar
Fly'n Brick
https://www.northamericanmotoring.co...ng-lights.html
Hope that helps.
Even after you get it all sorted out, the next time you rotate your tires you can get a warning light. Just go thru the reset routine and motor on.
Old Dec 5, 2011 | 05:11 AM
jpitchford's Avatar
jpitchford
Yep sure does. Thanks. I guess I'll be replacing that OEM rear control arm mount sooner than i wanted. It's torn now. So i bet that's it.
Waszak
Oct 21, 2017 05:55 PM
molala
Oct 2, 2015 01:53 PM
renchjeep
Sep 6, 2015 01:54 PM
