R56 Re-wiring Driving Lights?
Old Dec 2, 2011 | 05:13 AM
annabess1214's Avatar
annabess1214
Hi All!!
I just got my first Mini a few days ago! 2012, MCS BRGII. I added the driving lights to the front because I like the look, but was very disappointed when I picked up the car and the dealer told me they only turned on when the high beams are also on. As someone who lives in the city, I would almost never be able to use my driving lights. :(
Has anyone tried to re-wire the driving lights so they are not triggered by the high beam fuse? Has anyone tried to have the dealer do this for them? Looking for any suggestions on how to enjoy my driving lights a little bit more than just the retro look...
Thanks!!!
Anna
Old Dec 2, 2011 | 05:23 AM
Drobinson1692's Avatar
Drobinson1692
Yes. Go to the DIY thread and you can find it a guide.
...i'm convinced you just stole yours of another mini jk
http://www.amazon.com/UNIVERSAL-DRIV.../dp/B00514B34C
Old Dec 2, 2011 | 05:25 AM
richardsperry's Avatar
richardsperry
Think of them as EXTRA hi beams. They will blind oncoming traffic and will generally **** people off. They aren't designed to be used with the low beams.
Old Dec 2, 2011 | 06:24 AM
AustinS's Avatar
AustinS
And...in some states it is illegal to have them on with low beams.
Old Dec 2, 2011 | 06:34 AM
Maugre's Avatar
Maugre
I have mine wired independently of the headlamps, and have had rare oppertunities to use them for the above reason. They are totally useless for city driving, but they turn night into day on those dark lonely stretches.
Old Dec 2, 2011 | 06:50 AM
klricks's Avatar
klricks
Originally Posted by annabess1214
Hi All!!
Thanks!!!
Anna
Look up driving or auxiliary light laws on your states DMV web site. It is probably not legal in most states so the dealer will not rewire them.
Driving lights are not intended to be used in city driving anyway. In my state driving AND fog lights have to be dimmed to oncoming and when approaching other cars from behind just as if they were high beams.
It not connected to the high beams you would have 2 switches to flip at the same time.
Old Dec 2, 2011 | 08:36 AM
walk0080's Avatar
walk0080
Please don't use them as regular lights in the city. I am regularly blinded by people who insist on driving with high beams during night AND day in Toronto - and these driving lights will have the same effect on other drivers.
Old Dec 2, 2011 | 09:05 AM
schatzy62's Avatar
schatzy62
THis is where is sometimes gets real difficult to know what is right or wrong.
Georgia Code - Motor Vehicles & Traffic - Title 40, Section 40-8-29
(a) Any motor vehicle may be equipped with not to exceed one spotlight, and no lighted spotlight shall be aimed and used upon any approaching vehicle. It shall be unlawful for any person except law enforcement officers and persons licensed under Chapter 38 of Title 43 to operate a spotlight from any moving vehicle on any highway or public roadway.
(b) Any motor vehicle may be equipped with not to exceed two foglights mounted on the front at a height not less than 12 inches nor more than 30 inches above the level surface upon which the vehicle stands and so aimed that when the vehicle is not loaded none of the high intensity portion of the light to the left of the center of the vehicle shall at a distance of 25 feet ahead project higher than a level of four inches below the level of the center of the light from which it comes.
(c) Any motor vehicle may be equipped with not to exceed one auxiliary passing light mounted on the front at a height not less than 24 inches nor more than 42 inches above the level surface upon which the vehicle stands, and every such auxiliary passing light shall meet the requirements and limitations set forth in this article.
(d) Any motor vehicle may be equipped with not to exceed one auxiliary driving light mounted on the front at a height not less than 16 inches nor more than 42 inches above the level surface upon which the vehicle stands, and every such auxiliary driving light shall meet the requirements and limitations set forth in this article.
You will note that under Georgia Law two driving light is prohibited (see section d) But any dealer in GA will put on two driving lights and wire them in accordance with the way MINI has stated it should be done. So buying a new car straight off the lot with driving lights as a pre-purchase installed option will not meet Georgia Law.
Other states have different laws. So definitely check the laws in your state before rewiring or if you do be aware of the possible consequences.
Old Dec 2, 2011 | 09:33 AM
danigurrl's Avatar
danigurrl
I'd prefer mine to be independent. I'm installing them by myself though. I bought the driving light set and the grill and bracket mounts...do I still need that universal wiring kit? Or do the driving lights come with the wiring needed?
Old Dec 2, 2011 | 09:46 AM
Maugre's Avatar
Maugre
Depends on which driving lights you buy. Some come with the wiring kits, and others, you may have to buy wiring and relays and switches separate. I see you bought the lights and brackets already, so I'm guessing, therein lies the answer. Best of luck.
Old Dec 2, 2011 | 10:11 AM
danigurrl's Avatar
danigurrl
I bought OEM lights. And the OEM grill and bracket set. I didn't get it in the mail yet, so I'm not sure what it comes with for wiring yet.
Wohnson89
Jun 10, 2020 04:53 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
JHolland
Aug 13, 2015 10:47 PM
