05 "S" lites on 2011"S"
Old Nov 30, 2011 | 12:17 AM
fsufan0025's Avatar
fsufan0025
I have 2 mcs. 1 is a 2005 (yellow) and 1 is a 2011 (ice blue) The 2005 had 17 inch "S" lites while the 2011 had 16 inch silver 5 spokes. After thinking about it for 2 or 3 weeks, I decided to change the wheels, since the white wheels look so good on the ice blue 2011. But--no sensors in those wheels. Was told the sensors from the 2011 wheels wouldn't work\fit in the 05 wheels, so I need some sensors for the 05's !! Can anyone help ?? PLEASE !!
Old Nov 30, 2011 | 02:56 AM
HRM's Avatar
HRM
05 do not have any sensors. They monitor wheel speed rotation and if it varies, it knows one tire is under inflated.
Old Nov 30, 2011 | 12:33 PM
ScottRiqui's Avatar
ScottRiqui
It's true that the 2005 wheels didn't come with sensors, but I don't know for certain whether or not they'll accept sensors. The person to contact would be Alex at TireRack (either here on NAM or by calling TireRack directly). Also, even if the inner surface of the wheel isn't machined correctly to accept OEM MINI sensors, there may be aftermarket sensors that would work with the 2005 wheels.
Old Dec 1, 2011 | 03:01 AM
fsufan0025's Avatar
fsufan0025
Thanks guys. But -- the wheels I have were used from 03 to 09 so some of those years had the sensors. May try to buy a set for a 07 and try them. Do I have to run all 4 to turn off the damn light ??
Old Dec 1, 2011 | 07:28 AM
bluefox280's Avatar
bluefox280
Yes, you need all four TPMS sensors; one in each wheel.
- Erik
Old Dec 1, 2011 | 11:36 AM
Alex@tirerack's Avatar
Alex@tirerack
Do you have tires on the s-lites now?
Old Dec 1, 2011 | 11:41 AM
Blackbomber's Avatar
Blackbomber
I have a set of 2009 Crown Spokes (in silver, though) that I'd love to trade for S-Lites, since my car is a 2002. Too bad we didn't live closer (and my wheels are not white). That's a trade I would gladly do.
Old Dec 1, 2011 | 12:31 PM
quikmni's Avatar
quikmni
Also the 2011 has larger lug bolts than the 2005, 14mm verse 12mm diameter. I do not think there is an issue but you might want to make sure the 2011 14 lug bolt fits through the 2005 wheel hole.
Old Dec 1, 2011 | 12:36 PM
Blackbomber
If you look at his signature pic, he already is using the wheels. Really does look good, I must agree.
I can say from experiance that you can use the smaller lugs with the larger wheels, and I seem to recall it works the other way, also.
Old Dec 1, 2011 | 05:01 PM
ScottRiqui's Avatar
ScottRiqui
All of the OEM MINI wheels from both before and after the 2006 changeover from 12 mm to 14 mm bolts have the same size bolt hole diameter (approximately 16 mm). The bolt hole pattern and hub diameter have also remained unchanged since the beginning, so it's pretty easy to switch wheels amongst the various years of MINIs, as long as you can address the TPMS sensor issue when needed.
oeklm
Feb 17, 2016 01:00 PM
ryGuyMCS
Oct 6, 2015 12:04 PM
vargasgal
Sep 17, 2015 10:02 AM
shahriar35
Sep 14, 2015 11:53 PM
