Rear Brake Caliper Piston
Old Nov 23, 2011 | 02:51 PM
meStaq's Avatar
meStaq
The Bentley Service Manual (2007-2011) says that you need a special tool to move the rear brake pad piston, because it "turns the piston while pressing in." [I used a generic disk brake pad spreader just fine on the front pistons.]
Samstag Sales sells such a tool. However, when I emailed them to find out if it would work on a 2nd gen MINI (i.e. 2007-2011) they basically said they didn't know.
So, my question is: Will the same special tool that is used to move the rear brake caliper piston on a 1st gen MINI (thru 2006) work on the 2007's and later?
I happen to have a 2007 Cooper Hatchback.
Old Nov 23, 2011 | 03:06 PM
Capt_bj's Avatar
Capt_bj
yes
as long as the pins match up and in my experience they do
the e-brake system on MINI needs the piston turned as they are retracted due to a pad change / refresh
NOT unique to MINI
Old Nov 23, 2011 | 05:22 PM
toddtce's Avatar
toddtce
Pretty good universal one available at NAPA. Worth a look.
Old Nov 23, 2011 | 06:45 PM
daflake's Avatar
daflake
Got this cheesy one and it works just fine.
http://www.harborfreight.com/18-piec...kit-97143.html
jpgwinn24
Tires, Wheels, & Brakes
Aug 23, 2015 02:53 PM
jpgwinn24
R55 :: Clubman Talk (2008+)
Aug 20, 2015 06:57 PM
StealthR53
Aug 8, 2015 10:59 AM
