R56 Justa Cooper Getrag... Redline MTL or GM Synchromesh?
Old Nov 16, 2011 | 03:51 PM
honda93's Avatar
honda93
2012 Justa
6MT
Car will be autocrossed 12+ times a year with the occasional track day
850 miles - Yes, the car is new, but I'd want to have the best fluid in the car as early as possible.
Input or feedback?
Searching only made me ask myself more questions. Thanks in advance!
Old Nov 16, 2011 | 06:55 PM
jcauseyfd's Avatar
jcauseyfd
Can't say I've heard of anyone using the GM fluids in a MINI. Seems most folks opt for the Redline. That is what I went with, but mine doesn't get the severe service of autocross and track days that yours will.
Old Nov 17, 2011 | 04:42 AM
richardsperry's Avatar
richardsperry
To tell the truth, it probably doesn't matter what fulid you use. (talking about quality fluids here, Redline, Amsoil, RP, Mobil1, Valvoline syn...) Changing it more frequently, (30K miles) is way more important...
Old Nov 17, 2011 | 05:08 PM
MINI33342's Avatar
MINI33342
Stick with the oem fluid, it is a very robust high quality product. No need to change it.
Old Nov 18, 2011 | 03:56 AM
richardsperry
Robust, yes...
No need to change it? Eh, no.... At least if you want to own your car more than the warranty period...
Old Nov 18, 2011 | 09:56 AM
wludavid's Avatar
wludavid
Originally Posted by richardsperry
Robust, yes...
I think he meant, no need to move to a different brand.
Old Nov 18, 2011 | 11:48 AM
jlevy's Avatar
jlevy
Ive seen a definite difference between Redline and Mobil1 in several cars. The Mobil1 tends to be too slippery for the syncros and shifting is not as smooth. I ended "crunching" gears on all but the smoothest shifts. Also, in the past, the GL5 lubricants could shorten the life of brass and bronze parts significantly. I'm not sure if the formulation has changed in recent years, but this could be an issue too.
-JL
Old Nov 18, 2011 | 04:54 PM
MINI33342's Avatar
MINI33342
And 30K changes are even a bit to conservative.
Old Nov 19, 2011 | 11:29 AM
bluefox280's Avatar
bluefox280
All depending on the heat cycles; I have changed my Jetta's manual transimission fluid on several accounts:
* http://forums.vwvortex.com/showthrea...ge-(bluefox280)
Correct; GL-5 does ruin yellow soft metals (brass / bronze / etc).
The OEM fluid is a MTF-LT-4 (BMW Part No.: 83220421925)
- Erik
Old Nov 21, 2011 | 05:24 PM
MINI33342's Avatar
MINI33342
Same as short-changing engine oil, whatever lights your candle.
Not everyone will agree what intervals are best for either application, so go with what makes you and your wallet happy.
Old Nov 24, 2011 | 12:35 AM
pilotart's Avatar
pilotart
With an automatic, it is critical to only use the MINI recommended fluid, a lot of Chrysler Transmissions were ruined after using wrong fluid.
I would not want to take a chance of using a non-recommended Lubricant in a Manual either for warranty protection at the very least.
Old Nov 24, 2011 | 04:29 AM
glangford's Avatar
glangford
With a MT on a justa, what is the fluid capacity. I've got 38,000 miles on mine and am going to change it soon.
Old Nov 24, 2011 | 06:41 AM
bluefox280's Avatar
bluefox280
I'll check and get to you on Saturday.
- Erik
Old Nov 24, 2011 | 06:18 PM
Slave to Felines's Avatar
Slave to Felines
Mr. Bentley says 1.7 liters (1.8 quarts) for the Justa. 1.9 liters (2 qt) for the S.
Old Nov 25, 2011 | 04:16 AM
glangford's Avatar
glangford
Yes, that is what mini mania confirms. Its funny when I appiy my car info they filter out the redline option and show the only option is dealer fluid.
Old Nov 25, 2011 | 04:56 AM
cristo's Avatar
cristo
Alliance Member
That's because :
"Sorry, Red Line does not currently offer a replacement for the MTF-LT-4 fluid" (taken from the Redline Oil site's application guide).
They do offer a replacement for the earlier Coopers and Cooper Ss that take MTF-94 (Redline MTL) or MTF-LT-3 (Redline D6).
Old Nov 25, 2011 | 07:02 AM
glangford's Avatar
glangford
So I'm stuck with dealer fluid. The only fluid I can find comes in a 5 liter bottle for about 150 bucks. Anyone sell it in 1 qt bottles? You only need 2 qts. This might be one place where it is more cost effective for the dealer to do it.
Old Nov 25, 2011 | 09:41 AM
jcauseyfd's Avatar
jcauseyfd
You should be able to use the Redline MTL 70W80. The LT-4 is a lifetime rating for the oil. Obviously, if you are changing the oil in the MT, getting something rated for lifetime is not a requirement. Kind of like with the motor oil - if you are not going to follow the extended OCI, then getting something with the LL-01 spec is not really necessary.
Old Nov 25, 2011 | 10:23 AM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
We use the Royal Purple here at the shop. we like it a lot and they all tend to shift smoother after, as well as some cars see a very small bump on MPG.
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
PelicanParts.com
Aug 14, 2015 11:07 AM
Emnotek
Aug 13, 2015 05:47 PM
vballkid77
Cooper (non S)
Aug 10, 2015 04:44 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
