Suspension Suspension Shopping List..
Old Nov 15, 2011 | 04:52 PM
CAPO's Avatar
CAPO
Hi! I'm new at this.. so I have a simple question. I use my 2009 mini cooper S only as a daily driver.
I decided to go with the ST Coilovers with H-Sport Rear Camber Links.
Do I need anything else that is necessary?
Thanks!
Old Nov 15, 2011 | 05:26 PM
dannyhavok's Avatar
dannyhavok
You may need spacers depending on wheel offset, and a rear sway bar is a good bang for the buck suspension mod while youre at it. I have st coilovers waiting to be installed, got them from the suspension source. will be getting 5 millimeter spacers from euro sport design and doing the install in the spring.
Old Nov 16, 2011 | 01:16 AM
CAPO's Avatar
CAPO
dumb question.. are u getting spacers for all wheels? or only back the back or front?
Old Nov 21, 2011 | 07:27 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes depending on your wheel and tire combo you may need wheel spacers. Also while your doing it you should install a rear sway bar if you don't already have one.
Old Nov 21, 2011 | 07:41 PM
brohammer619's Avatar
brohammer619
Why would you need spacers? Because the springs are different sizes (outer diameter)?
Old Nov 22, 2011 | 01:24 PM
TheSuspensionSource's Avatar
TheSuspensionSource
You need the wheel spacers to kick the wheel away from the coilover body. I am running a Thanksgiving special. $75 off ST coilovers.
Old Nov 22, 2011 | 06:10 PM
Phx JCW's Avatar
Phx JCW
Speaking of rear sway bars...I may have mine installed professionally at the same time my coilovers go on.
What are people paying to have this done? Either sway bar and coilover together, or individually.
Old Nov 23, 2011 | 11:46 AM
richardsperry's Avatar
richardsperry
I seem to be getting some doughnuts and cokes when i installed his suspension (s). But that's a good deal for him...lol After all he's a good friend and I like doing it.
But figure about 5 hours of shop time. The rear bar only takes about a 1/2 hour if you are doing rear shocks at the same time.
Drop rear subframe, unbolt bar remove, wiggle new bar in and bolt it up.
Old Nov 23, 2011 | 04:10 PM
Phx JCW's Avatar
Phx JCW
Thanks for the estimated time. I could throw in some bear claws for your time
Old Nov 23, 2011 | 04:52 PM
phxsteele's Avatar
phxsteele
My garage is always open to fellow mini owners. Our local club just had a tech day at a garage with a lift and quite a few members installed various suspension mods that day. I've done coil overs and sway bars in my garage no problem.
Old Nov 24, 2011 | 12:20 PM
Phx JCW's Avatar
Phx JCW
Where and when do the owners meet? Would be interest once my car is in my hands.
Old Nov 28, 2011 | 05:14 PM
knife's Avatar
knife
Phx MINIs
Ditto! I'd def be interested--been saving up all my mods to do at once as well When's the next meet?
Old Nov 28, 2011 | 05:50 PM
dannyhavok's Avatar
dannyhavok
Not a dumb question, it took me awhile to figure this one out Apparently you only need spacers on the front. I'm going to get them all around just so everything is even on all four corners, and on the off chance I'm being misinformed about what's necessary.
Old Nov 28, 2011 | 05:53 PM
Phx JCW's Avatar
Phx JCW
Got mine for all 4 corners as well. I didn't want a difference stance from front to back.
Old Nov 28, 2011 | 06:03 PM
countryboyshane's Avatar
countryboyshane
I don't think anybody's going to be able to tell. If you're lowering, you need to tuck as much as possible anyway to prevent tire rub on the wheel arch.
Old Nov 28, 2011 | 08:10 PM
phxsteele's Avatar
phxsteele
We meet a couple time a month. Check out the club website www.dynamicminicollective.org
Old Nov 28, 2011 | 08:56 PM
knife's Avatar
knife
thanks for the info!
Old Nov 30, 2011 | 11:35 AM
phxsteele's Avatar
phxsteele
For those in the Phoenix area we are having our monthly go kart night tonight at K1 Speed by the airport. 7pm. Stop by and say hi and meet a few club members.
ej
Nov 17, 2015 09:21 PM
jarymo
Hawaii MINI Motoring Club
Sep 30, 2015 04:19 PM
Panik
Sep 9, 2015 08:36 AM
mikeson
Sep 6, 2015 06:21 AM
Suspension Products
Sep 3, 2015 09:41 AM
