Get new TPMS or reuse?
Old Nov 14, 2011 | 01:20 PM
nykwan's Avatar
nykwan
I'm getting ready to order my winter tires, and I'm going to mount them on my same wheels and toss out my summer runflats, esp since one tire seems to have developed a slow leak.
I've seen people say you need new TPMS cause they don't reseal well and can leak if re-used.
My car is only 5months old, so are the TPMS ok to re-use again when I swap tires (same wheels) since they aren't that old?
Old Nov 14, 2011 | 04:56 PM
ZippyNH's Avatar
ZippyNH
The sensors are re-used indefently....the batteries are usually replaced, but yours are so new, no need. A set of new sensors is actually more $$ than new tires in many cases....i think you need a new source of onfo...
Old Nov 14, 2011 | 05:48 PM
fused's Avatar
fused
Just put new Non Run Flat tires (to get rid of that Run Flat Flintstone ride) on mine and the same sensors were kept on the rims. Reset the TPMS once new tires were on and has been fine....
Old Nov 14, 2011 | 08:16 PM
MisterClean's Avatar
MisterClean
Get a TPMS rebuild kit for the tire sensors. Doesnt cost much and you reuse the sensors.
Old Nov 14, 2011 | 08:59 PM
ballandchain's Avatar
ballandchain
Thats what I was told to do, I believe it was like $6/ wheel.
Old Nov 14, 2011 | 10:00 PM
chaswyck's Avatar
chaswyck
It's probably worth $6 a wheel for the peace of mind, but I want from RF's to non'RF's on my 335i and didn't do a thing to the TPSM sensors and they worked fine.
Old Nov 15, 2011 | 01:07 PM
MisterClean
Just make sure after the tires are installed that you check the tire pressure religiously. The person that installed my tires accidentally put an extra washer on one of the sensors and I had to return to get it fixed. Thats the short version....in reality my sensor went off because the tire lost over half the pressure and I almost missed work because of that.
Old Dec 1, 2011 | 02:21 PM
Alex@tirerack's Avatar
Alex@tirerack
OEM TPMS sensors are a sealed devise, when they run out of batteries - replace your sensor. The sensors have a tiny tilt switch inside them, so they only transmit while you drive. Average life is 4-7 years.
I'd use the rebuild kits as long as your sensors are still working.
Old Dec 21, 2011 | 04:09 PM
gutterman's Avatar
gutterman
So how much should you pay for new TPMS sensors , I was looking wheel and tires combo and they wanted $49 each wheel . 07 so when I replace tires I should need new sensors .
freckles81
Jan 15, 2017 06:33 AM
OldElvis
Tires, Wheels, & Brakes
Oct 1, 2015 06:21 AM
MCSNY
Sep 29, 2015 10:17 AM
renchjeep
Sep 6, 2015 01:54 PM
