R50/53 Confused over control arm bushing repair
Old Nov 11, 2011 | 10:35 PM
Ole97Texas's Avatar
Ole97Texas
2004 S with 98k. Mini dealer in Tennessee said control arm bushings are torn & need replacing. Local Firestone shop said they look good. Is there something different on Mini's that we are overlooking? Don't want to replace them until needed.
Old Nov 12, 2011 | 12:25 AM
BlwnAway's Avatar
BlwnAway
Not that I know of, maybe you need a 2/3. If you change them I really like my Powerflex.
Old Nov 12, 2011 | 12:49 AM
Minian's Avatar
Minian
At 98k they are bad or soon will be.
Old Nov 12, 2011 | 05:11 AM
MI_MINI's Avatar
MI_MINI
My understanding is they are shot at 60k. Go with Powerflex for sure.
Motor On!
Chris
Old Nov 12, 2011 | 06:21 AM
element's Avatar
element
I went with the Alta PSRS which added more metal and stiffer bushings.. should 2x the life compared to the OEM design.
Old Nov 12, 2011 | 08:51 AM
ofioliti's Avatar
ofioliti
Mine were bad at ~60K.
Here's a quick way to check if they are bad. Note how the second wheel appears "loose" upon kicking it:
http://www.youtube.com/watch?v=JtElI_WknGs
Old Nov 14, 2011 | 10:37 PM
Ministrater's Avatar
Ministrater
I never kicked the tires but I could feel a pull while braking when mine went bad.
Old Nov 15, 2011 | 10:28 PM
Rossii's Avatar
Rossii
I was told mine was bad around 45K had them replaced with Power flex but the shop the replaced them told me that the stock ones were ok.
W0TM8
Dec 19, 2019 07:50 AM
Mini7
Feb 2, 2016 07:52 PM
Toolman
Jan 20, 2016 06:50 AM
maestro39
Oct 27, 2015 02:38 PM
JPMontes3
Aug 23, 2015 01:26 AM
