R50/53 Spark plug gap on R53 S?
Old Nov 10, 2011 | 05:47 PM
minirooferS's Avatar
minirooferS
I just got a set of NGK iridium plugs for my cooper S and want to know what they should be gapped at. I've read that they are pre gapped to 0.032, is that OK?
Oh and I don't have a torque wrench so how do I know when to stop tightening?
I really know nothing about this.
Old Nov 10, 2011 | 06:57 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
The book says 20 ft lbs.
That gap is AOK for stock coil pack and wires.
If you ever add a performance CP, you can open that up .010 or more.
Old Nov 10, 2011 | 07:13 PM
ZippyNH's Avatar
ZippyNH
Buy a tourque wrench...pretty cheap at harbour freight/walmart...
Cheaper than getting a plug blown out or stripping the threads and needing a helicoil/rebuilt head..
If you don't know about tjis stuff...maybe itis time to do a realirty check...ask a freind too...
One poor fellow installed the wrong plugs...blew up his motor...be has like 3 threads going...bent the valves on 3 cylandars, maybe broke a piston....very $$ mistake.
Old Nov 11, 2011 | 12:23 AM
Applesauce's Avatar
Applesauce
I gapped mine at .045", but still didn't like them and switched back to MEG plugs.
As others have said a) make sure you have the right plugs and b) BUY A TORQUE WRENCH. There's not much you can or should do on a vehicle without one.
Old Nov 11, 2011 | 12:25 AM
element's Avatar
element
#1 rule of working on your own car - torque everything back to factory spec! It's a simple and cheap insurance policy and you are already saving $$ by doing it yourself!
phil.
Old Nov 11, 2011 | 07:53 AM
minirooferS
Ok thanks. Will do. I did get the right plugs though. I atleast know that
Old Nov 13, 2011 | 06:39 PM
Gizmo's Avatar
Gizmo
Hand tight then quarter turn with the wrench.
As mentioned before, they are pregaped and don't need to be adjusted.
Old Nov 13, 2011 | 06:49 PM
minirooferS
Yea everything went fine. The car runs soooo much smoother now. Very impressed
Old Nov 13, 2011 | 07:42 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
phil.
Good recommendation for a first timer, a blown out plug will cost alot more than a torque wrench.
maniacalmorgan
Jan 1, 2020 11:20 AM
silence2-38554
98
Sep 21, 2016 02:52 PM
maniacalmorgan
38
Sep 29, 2015 04:56 AM
HaveATank
Sep 4, 2015 08:04 AM
yashmack
Aug 15, 2015 10:16 AM
