Interior/Exterior My Hood is crooked
Old Nov 4, 2011 | 06:26 PM
Porthos's Avatar
Porthos
My Hood is crooked
I was just looking at it when I got home and it is seriously crooked and I am not sure why and what I am going to do to fix it. Any help would be appreciated.
Old Nov 5, 2011 | 04:55 AM
drewstermalloy's Avatar
drewstermalloy
Any pictures? Are you sure it's the hood and not the bumper?
Old Nov 5, 2011 | 08:55 AM
mini4tide's Avatar
mini4tide
Mine is too. The right side has a little more of a gap. You can kind of see it here...
Old Nov 5, 2011 | 09:30 AM
walk0080's Avatar
walk0080
Nice blue Union Jack you got there.
Old Nov 5, 2011 | 09:50 AM
DneprDave's Avatar
DneprDave
On mine, the hood sometimes doesn't latch on one side or the other, especially when I close the hood too gently, it makes the hood look crooked. Try opening the hood and then close it firmly and see if that fixes it.
Dave
Old Nov 5, 2011 | 10:10 AM
pew1375's Avatar
pew1375
My bonnet looks off in a couple of places, I figured it's either a bent hood or miss aligned hinges.
It's not a huge deal, but it does bug me.
I just replaced the hatch hinges, and they were a nightmare. Those require getting under the headliner, so in my R53 it requires taking out back seats, interior panels, pillars, and hand holds (among other goodies here and there).
I wouldn't think it would be too hard to re-align the bonnet.
Old Nov 5, 2011 | 08:49 PM
Yyrd's Avatar
Yyrd
My passanger side never latches too. i grab the wheel well with one hand and push hood with other, back and forth till it grabs. very anoying.
Old Nov 6, 2011 | 02:24 PM
10Zero's Avatar
10Zero
Adjust it with the rubber adjusters on the left and right side. Same type of adjusters on your hatch.
Old Nov 7, 2011 | 09:48 AM
Porthos's Avatar
Porthos
When I get home tonite I will post Pictures. I was way too damn tired this weekend working security at our base air show.
Old Nov 7, 2011 | 11:48 AM
SooperCuperErik's Avatar
SooperCuperErik
yeah you can adjust the rubber grommets but they don't do too much for me. I have to grab the side that doesn't close as far down (by the latch on the hood) and pull down on that side to close it. Usually that extra force helps get it in, but, overall these latches are awful.
Even in the boot, the latch makes awful noise and becomes loose. The fix is putting electrical tape around the U latch on the hatch. When my dealer saw that they swapped the latch assembly, it solved the issue for a few weeks, then came back. Back to the electrical tape now.
AWFUL QC FTL
Old Nov 7, 2011 | 11:55 AM
Bigprfed22's Avatar
Bigprfed22
If your measuring how much fender you see per side when closed and looking from above... no mini has a straight aligned hood.
Old Nov 7, 2011 | 01:15 PM
Achilles honor's Avatar
Achilles honor
Mines a tad crooked too. all the minis ive see have a tad crooked hood. nothings perfect. thats what makes it unique.. <--- the most un helpful comment yet lol
Old Nov 7, 2011 | 03:55 PM
Porthos's Avatar
Porthos
Old Nov 7, 2011 | 05:38 PM
cccplus's Avatar
cccplus
there's a way to fix the gap. the latch/hook on the bonnet can be adjust. just remove the rectangular plastic covering around the latch and adjust the latch by twisting it clockwise/counter to adjust the gaps.
Old Nov 8, 2011 | 06:07 PM
Porthos's Avatar
Porthos
I will give that a try and see what happens.
Old Nov 12, 2011 | 07:50 PM
Porthos's Avatar
Porthos
There are some rubber bumpers if you will under the hood and I adjusted them and now it is fixed. I might play with them more so give it a little more of a tighter fit. But it is fixed.
Old Nov 26, 2011 | 04:43 PM
isthar's Avatar
isthar
FYI, I once had a different gap size on each side, dealer corrected but now if I tap on the hood (or use a duster), when on one of the corners you can hear the hood clank up/down. Adjustments exist, but you have to be careful with them, clearly, as you fix one thing and start another problem.
Old Nov 27, 2011 | 06:56 AM
Porthos's Avatar
Porthos
Yes I already fixed it and I don't take my car to the dealership anymore because it is not under warranty anymore.
Old Nov 27, 2011 | 07:44 AM
Minibeagle's Avatar
Minibeagle
Dave
+1
OutMotoring
Mar 3, 2017 06:29 AM
Colt45Magnus
Oct 1, 2015 04:08 PM
M7Speed
Oct 1, 2015 07:05 AM
mini merle
Sep 30, 2015 04:42 PM
drum6g
Sep 29, 2015 01:15 PM
