Suspension Lowering springs and floor jacks
Old Feb 12, 2004 | 08:38 PM
Verruckt's Avatar
Verruckt
I've been thinking of putting H-Sport springs on my MCS, but am curious... anyone have problems getting a jack under there after lowering?
Old Feb 13, 2004 | 09:14 AM
Moorlockx's Avatar
Moorlockx
I've got H&R's and The bottom of the lift points are only 4.5" off the floor. I've to drive my car up on a piece of 2x6 to get the clearance needed for the jack that I've got.
Anyone know of a compact floor jack that gets down to 3.5" to 4"?
Old Feb 13, 2004 | 09:16 AM
dave's Avatar
dave
pug poo picker-upper
The Harbor Freight Jack will have no problem sliding under lowered MINIs. :smile:
Old Feb 13, 2004 | 09:36 AM
Yucca Patrol's Avatar
Yucca Patrol
Harbor freight rocks for cheap and relatively durable Chinese tools!
Especially great when you need a tool for just one use and don't want to pay Craftsman or Snap-on prices!
Old Feb 13, 2004 | 09:46 AM
BlueMCS's Avatar
BlueMCS
The aluminium floor jacks (all made from the same castings - price $100-200) fit a lowered car just fine if you insist on using the jack pads. Any floor jack will work if placed just behind or in front of the pads.
Old Feb 13, 2004 | 10:37 AM
Marcomini's Avatar
Marcomini
Have the H-Sport and the harbor freight racing jack as well. No Probelms. If you check Harbor freight right now I know the jack can be bought for around $120 a great price. I also use the rhino ramps got mine at Pep Boys for $15. Between those two I can almost do anything.
Good Luck, You'll enjoy your H-Sports, Love mine.
Old Feb 13, 2004 | 10:58 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
I have the H-sport springs (lowers the MINI one inch front and rear) on an MCS and use the aluminum racing jack from Checkers- roughly $165 on sale or $199 with two aluminum jack stands. The jack works just fine.
HR springs are a bit lower and the racing jack doesn't fit- you'll have to drive the MINI onto some 2x6 pieces of lumber to increase the height enough to get the jack under the car.
Old Feb 13, 2004 | 11:15 AM
kenchan's Avatar
kenchan
since we're on the subject of jacking up a car, where do you use to
jack up the front and the rear respectively?
Thanks. :smile:
Old Feb 13, 2004 | 12:41 PM
ubercooper's Avatar
ubercooper
>>Thanks. :smile:
The support for the front suspension is a raised box of metal in the floor (ok actually it is a lowered box) that runs just inside the jack points. If you go to the end of the box you can jack the entire side of the car in 1 shot. ScottBRG amazed me when he did this to my mini for the swaybar install.
ubercooper
Old Feb 13, 2004 | 12:59 PM
2Cool's Avatar
2Cool
Another vote for the Harbor Freight jack, and I find that when I use the front jack point it will lift the entire side of the car with no worries. I did this when I changed my brakes, and again when I did the H&R springs.
Old Feb 13, 2004 | 01:03 PM
friedduck's Avatar
friedduck
If I'm putting it on stands (with the stands supporting the 4 jack points) then I put a piece of 2x4 under a square section of steel just inboard of the front jack point about 3-5 inches. (It's a box-section channel that runs longitudanally)
That's enough to get the entire side of the car in the air high enough to get the jack stands in. If I'm just rotating tires I'll put the jack under one of the normal jack points.
Jeff
Old Feb 27, 2004 | 12:39 PM
Verruckt's Avatar
Verruckt
So can you still use the Rhino ramps unassisted, or do you need the 2x6 for those as well?
thanks!
Old Feb 27, 2004 | 03:30 PM
ABTsportsline's Avatar
ABTsportsline
Harbor Freight Jack is on sale for $90 right now....
http://www.harborfreight.com/cpi/cta...emnumber=91039
cheers
-ABT-
Old Feb 27, 2004 | 03:33 PM
dave's Avatar
dave
You can get a lowered MINI up the Rhino Ramps without any rubbing/dragging on the ramp (no 2x6's required). I have done this many times with the H&R springs and those drop the car a little lower than the H-sport springs.
_________________
David Bunting :: North American Motoring :: Send me a PM
melscoop
Mar 30, 2016 06:56 PM
thebordella
Aug 31, 2015 01:37 PM
G1HQ
Aug 28, 2015 01:41 PM
yukinoinu
15
Aug 24, 2015 09:20 AM
Emnotek
Aug 13, 2015 05:47 PM
