R50/53 This isn't true, is it?
Old Sep 21, 2011 | 09:15 PM
Dennis Bratland's Avatar
Dennis Bratland
The Peake Scan Tool may or may not read BMW specific codes. But what about this bit...
... For example, you've done an oil change yourself. If you don't have this scan tool, the lights on the dash need to be reset, which means making an appointment at the shop, and taking it in to the mechanic, and all that hassle just so the shop can plug in their tool and reset everything. Then you have to pay a bill for that service. You don't need to go through any of that hassle if you have your own scan tool!
As posted in several places, and on page 020-36 of the Bentley manual, you reset this by holding the trip reset button, turn ignition to position 1, wait for current status, release trip button, press and hold trip button for 5 seconds, until it flashes rst, then press trip again. And say five Hail Marys.
Old Sep 22, 2011 | 02:53 AM
pgrzes's Avatar
pgrzes
I pulled this from this forum somewhere. Just did oil change last week. And after some trial and error It does work.
Resetting Oil Service Light on your 2002 - 2006 MINI Cooper and Cooper S, and 2007 - 2008 MINI Convertibles:
1) Press and hold the trip button
2) Insert key and turn to position 1
3) Watch for RESET to appear
4) Release the button, then press & hold it again
5) Wait for the RESET to flash
6) Release the button, and then press & release (once only)
7) Service interval should then be reset to next interval
If that didn't work, try this:
1. Push the Trip Button
2. Turn ignition key to position 1 and 51A will appear to left of mileage
3. Release trip button
4. Wait 3 seconds
5. Push trip button
6. Wait (5-8 seconds) for RST to appear in left corner
7. Release trip button
8. Push trip button
9. 15000 will appear as new service interval
10. Release trip button
Or this:
1. Press and hold the trip odometer button.
2. Insert car key and turn it to the fi rst position (not the second position).
3. You will see 51A come up in the trip odometer area.
4. Release, then press and hold again.
5. Watch for the word “RST” to appear on the Odometer indicator.
6. Release, then press and hold again.
7. Wait for the “RST” message to fl ash.
8. Release, and then press & release (once only).
Old Sep 22, 2011 | 05:12 AM
ofioliti's Avatar
ofioliti
What they say is true if you don't know about the method you describe and you aren't Catholic.
Old Sep 22, 2011 | 09:10 AM
quikmni's Avatar
quikmni
Resetting the oil change counter can be very trial and error when doing it manually. It usually took me a few tries to get it reset manually. I purchased the Peake Tool and life is much easier.
Old Sep 24, 2011 | 08:18 AM
Dennis Bratland
Quikmni, I'm not sure I'd spend $139 on a tool that you use once every 6,000 to 15,000 miles. I did my oil yesterday and somehow reset it the first try -- probably because I'd been warned it was tricky and was paying extra attention to follow the instructions exactly. And they really ought not to tell you your only other choice is to take it to the dealer.
The other part, about reading codes that a normal OBD II reader can't is interesting. I [strike]should email[/strike] emailed them and see if they can be more specific.
Old Sep 24, 2011 | 08:24 AM
bosfordjd's Avatar
bosfordjd
Yeah I got the peake tool for that and to read a code I was getting at the time, still have never been able to get the peake tool to reset it, tried a million times, always end up doing manually so I wouldn't waste the money just to reset the service timer.
Old Sep 24, 2011 | 08:30 AM
Kathy1946's Avatar
Kathy1946
Old Sep 25, 2011 | 07:56 AM
quikmni's Avatar
quikmni
I sure have got adequate usage out of the tool. Over the 8 years of having Mini Coopers I have used it about 20 times to reset the oil change counter on mine and other Minis. I have also used it multiple times to read and reset codes on my car and other Minis. You can also find the tool on sale or for sale used.
I sure have purchased other $100 tools that I have used much less than the Peake tool.
Old Sep 25, 2011 | 06:13 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Quikmni, I'm not sure I'd spend $139 on a tool that you use once every 6,000 to 15,000 miles....
Do an eBay search on "Mini Cooper Reset" and you will find a tool that works perfectly, is easy to use and only cost $17 including shipping.
It won't read codes but it will do the resets with no drama.
Rich
SJ-R50
Oct 28, 2015 08:39 AM
eMINI of the State
Oct 2, 2015 03:12 PM
potterstein
Oct 1, 2015 07:10 AM
Huskyfan
GP Talk
Sep 28, 2015 06:08 PM
ericf1993
Sep 26, 2015 03:58 PM
