R50/53 Pulley/Iginition/CAI cost to install
Old Aug 29, 2011 | 03:12 PM
j3r3my's Avatar
j3r3my
I am looking to have a pulley, new ignition parks and a cai installed, and the later two I can do my self, but the pulley is more than I want to take on. I got a quote to install everything for $250 (new pulley, belt, tension retainer thing, cai, ignition).
I can handle the work, I just don't know how long it will take and I work a lot.
Old Aug 29, 2011 | 04:54 PM
minimic's Avatar
minimic
that sounds like a good deal to me, as i just had a pulley installed and it cost me about $220. i was not about to attempt the pulley myself. i say go for it, if you can't find any one to do it for cheaper. are you getting a tensioner stop? if so go with detroit tuned stop.
Old Aug 29, 2011 | 06:46 PM
ZippyNH's Avatar
ZippyNH
Price seems fair....I have seen a pulley done by a very experanced mechanic, and a detroit tensioner stop installed in under a half hour....but I think most places will want the car for a few hours...especially if you are changing the spark plugs to one step cooler jcw plugs...they should be torqued and installed in a cool (not hot) head. It all comes down to repetition....folks used to have pulley parties where the puller was shared, and a number of cars would be done togeather with one experanced person helping out...along with some cold beverages and pizza ...
Old Aug 29, 2011 | 07:18 PM
j3r3my's Avatar
j3r3my
That would be cool, but I do not know anyone else with a mini apart from this site.
I think I'll just let them do it. I was thinking the alta kit, any suggestions?
Old Aug 30, 2011 | 06:31 AM
rlich8's Avatar
rlich8
You should be able to do the ignition stuff yourself. The coil bolts right on to the engine and is in plain view. It requires 4 bolts to be removed. Disconnect all the ignition leads and the lead to the computer. Reinstall.
Spark plugs are pretty easy too, they're in plain view.
I say do the ignition stuff yourself. If you ever have a problem on the road somewhere and need to make a quick, on the fly repair, then you know exactly how to do it because you've done it before! Plus, in the old days of points, caps, rotors, you always had to know a thing about the ignition system. This is no different, you just don't have a distributor! That coil "could" go bad on the side of the road somewhere! Unlikely, but it could.
Have fun!
Old Aug 31, 2011 | 06:40 AM
ZippyNH's Avatar
ZippyNH
The alta kit is fine...waymotorworks has one too...has the tensioner stop that will not rattle like the alta one can. The stock coil is pretty good...I swapped mine with a msd coil due to corrosion on the terminals, but changinging is not needed, it just makes stuff look good, but does not makes any real power...doing the pulley you 100% need to buy, rent, or borrow a special tool...a standard pullers puller WILL NOT WORK. Some have cut it off with a cutting wheel....but the puller makes it a 5 minute job....
If you ever do the tourist thing to philly, therse is a good/great shop there for minis...
Old Aug 31, 2011 | 01:45 PM
j3r3my's Avatar
j3r3my
Are there any good shops within 500 or so miles from Vegas? I will be near Sacramento over this weekend, so few hours from Sacramento, ca?
Will consider Way than, do not want a rattle.
Old Sep 1, 2011 | 01:15 PM
ZippyNH's Avatar
ZippyNH
Lots of places on the west coast, heck 2 of the leading tuners/misters
Thought you were back east!
Guess I need to look at you signature/location closer!!
Old Sep 1, 2011 | 01:27 PM
purplehaze05mcs's Avatar
purplehaze05mcs
Danny at MiniCorsa (818-505-8240) did mine while waiting. Awesome!
Old Sep 1, 2011 | 01:58 PM
j3r3my's Avatar
j3r3my
Called Danny, going in on the 17th. Thanks for the referral.
Old Sep 1, 2011 | 07:00 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
If you have any questions about our kit let us know, it's just what you need and not too much. Too bad your not in San Diego we have an installer there.
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
Aug 21, 2015 11:25 AM
