Suspension JCW suspension and alignment ?
Old Aug 17, 2011 | 04:07 PM
Ladyvalea's Avatar
Ladyvalea
I'm going to get a JCW suspension installed by the Dealer...just a quick question... The dealer said that they do the alignment on the same day as the install! Now, I thought your suppose to let the springs and stuff settle and then do the alignment a couple weeks? or months? ???
I'm confused? does it matter?? thanks
Old Aug 17, 2011 | 06:33 PM
slinger688's Avatar
slinger688
I would let the suspension settle if it was my car. You only need to run it a couple of 100 miles then get the alignment.
Tell the dealer you rather come back later for the alignment and they should be good with that.
Old Aug 18, 2011 | 09:58 AM
nicrc211's Avatar
nicrc211
Just let them do the alignment then do another one in a month. If you don't do an alignment it will eat your tires.
Old Aug 18, 2011 | 06:29 PM
10Zero's Avatar
10Zero
The JCW only drops it about 1/2", I seriously doubt that 1/2" will jack the camber and toe up so much that it'll "eat" your tires. Will probably find it still very close to the OEM specs for alignment...unless of course they completely FUBAR the installation.
Old Aug 19, 2011 | 10:08 AM
Ladyvalea's Avatar
Ladyvalea
thanks you everyone for all your suggestion...
maestro39
Oct 27, 2015 02:38 PM
Minibeagle
Aug 13, 2015 10:00 AM
nomar116
Aug 10, 2015 11:24 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
