R55 Warning Light...Engine Too Hot
Old Aug 17, 2011 | 11:41 AM
Prost's Avatar
Prost
I had the warning light (one with a thermostat and coolant thing) in yellow light up while driving in my Clubman two times in three days, it will pop up for about 10 seconds and gone (both times), I am in SoCal and this past week is not really that HOT (80s to 90s). I check the owner's manual and it said if the light in Red is "Overheating" and if yellow, it is "Engine Too Hot"...what does that mean? I scheduled an appointment next week to take a look but are there anyone experience something similar before?
Old Aug 17, 2011 | 07:28 PM
MightyNuts's Avatar
MightyNuts
check the oil? maybe a leak?
Old Aug 19, 2011 | 06:39 AM
timfitz63's Avatar
timfitz63
Originally Posted by MightyNuts
check the oil...?
Regularly checking the oil level is always a good plan, but for an overheat situation, one should check the coolant level first. If that's fine, you may be looking at a sticky (or stuck) thermostat. Or even a bad water pump.
If you're driving about and get warning lights about the engine overheating, you should also turn on the cabin heat. I know that can be uncomfortable during the summer months, but it might help to cool the engine by drawing heat away from it and dumping it into the passenger cabin. You can always open the windows and/or sunroof to expel the heat from the cabin. And a quick shower is cheaper than a new engine...!
And of course, if you're leaking coolant badly, this action (turning on the cabin heat) will be, at best, a very temporary solution.
Old Aug 23, 2011 | 12:08 AM
Prost's Avatar
Prost
Dealer found out it's because of "leaking turbocharger cooling pump" and leaking water pump...maybe the combination of those tow things together. will get my Clubman back tomorrow
Old Aug 24, 2011 | 07:40 AM
Prost's Avatar
Prost
I guess the "turbocharging cooling pump" is aka "auxiliary cooling pump" as listed on the repair order sheet.
potterstein
Oct 1, 2015 07:10 AM
OldElvis
Tires, Wheels, & Brakes
Oct 1, 2015 06:21 AM
ericf1993
Sep 26, 2015 03:58 PM
rt808
Sep 25, 2015 01:59 PM
