R50/53 M7 DFIC corroding, advice needed
Old Aug 9, 2011 | 10:36 AM
MrNintend0's Avatar
MrNintend0
Ok guys, I recently bought a used M7 DFIC (the standard polished version) and cleaned it up using Varsol. After letting it dry for a few days, I noticed some corrosion built up on it on the outside. I thought "No problem, doesn't hurt anything, just looks bad. I'll polish it up a bit, and it'll be good as new". Well, sadly I found out it got worse. Not only did it corrode on the outside, but on the inside as well, and there's a lot more in there than there is on the outside. I have searched Google and have yet to find anyone else, MINI Cooper affiliated or otherwise, who has a similar problem.
I doubt it's the Varsol that caused this. When I first got my MINI, I cleaned out the stock IC with Varsol and left it off the car for about a week and a half (Mind you it was in surgery for maintenance for that time) and it had never done this, in fact there wasn't a bit of corrosion on it when I was done.
I need advice on what to do for it. How can I remove the corrosion and keep it out of the IC? The only thing I can think of is to get the entire IC acid dipped and anodized, which will probably cost me an arm and a leg.
Thanks for any help,
MrNintend0
Old Aug 9, 2011 | 10:49 AM
quikmni's Avatar
quikmni
Have you contacted M7 Tuning and what was their response to the corrosion?
Old Aug 9, 2011 | 11:52 AM
MrNintend0's Avatar
MrNintend0
Hadn't thought of that, I'll contact them when I have time today, thanks for that
Old Aug 9, 2011 | 12:43 PM
rkw's Avatar
rkw
Did you notice any corrosion at all when you were first cleaning it? Post some pics if you can.
Melvinyip
Apr 17, 2020 09:28 AM
boostedhaze
Jan 2, 2018 07:26 PM
iwant2knowwhois
11
Sep 19, 2015 12:18 PM
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
Herleman
Aug 16, 2015 06:41 PM
