R50/53 GaUgEs?? ?
Old Jul 22, 2011 | 04:34 PM
03miniac's Avatar
03miniac
GaUgEs?? ?
Quest to figure out adding gauges to project.
Many of you have gauges stroomed through out the drivers area that have a serious price tag attached.
I'd like to keep the clean look without all that cluster clutter.
Have thought about somehow using an IPad to display gauge reports.
Any thoughts?? ?
Old Jul 22, 2011 | 06:28 PM
DneprDave's Avatar
DneprDave
There's this,
http://www.aeroforcetech.com/products_interceptor.html
Dave
Old Jul 22, 2011 | 06:43 PM
03miniac's Avatar
03miniac
Originally Posted by DneprDave
That's great direction. Cheap & all one unit. Definately read into it.
One main question on my mind is seeing as there can only be 2 on display at time can a check engine warning pop up for another.
Thx again Dave!
Old Jul 22, 2011 | 09:55 PM
Motor On's Avatar
Motor On
Garmin's got a multi-gauge display built into a GPS unit. Perhaps a little less enticing for thieves than an Ipad, or easier to tuck away in the same spirit.
I personally use the ScangaugeII for all the parameters that I can fit into the small display, it shows 4 at once, and it's pretty easy if I want to change which of the 4 I want to be displaying.
I haven't seen any for the ipad specifically but I know there's some OBDII readers and itouch/iphone apps that do the same basic thing, but I'm not sure of the compatibility and mounting options.
Old Jul 23, 2011 | 01:35 PM
03miniac's Avatar
03miniac
Doesn't need to be in eye view.
There is a factory NAV system installed so maybe something like this Garmin that could replace the screen & be able to download log reports.. .
Old Jul 23, 2011 | 02:17 PM
Capt_bj's Avatar
Capt_bj
a similar discussion in another thread asked, "what things do I want to monitor with added gauges?" (or words to that effect)
IMHO the top of the list is oil pressure . . . to wit, what are the aux gauges that came on the original Cooper? Oil pressure and coolant temp.... {the GEN1 MINI at least had a temp gau'}
Curiously none of the electronic multi-gauge solutions can read oil pressure ... or none I've seen anyway. It appears that oil pres' is NOT something tied into OBDII. This surprises me but ..... that's what ya got.
So if you want bling . . . display anything
If you want useful you just might have to hang at least ONE real gauge . . .
Old Nov 18, 2011 | 03:07 PM
03miniac's Avatar
03miniac
Tried the Scangauge II for the past couple months & nice unit but just not final result looking for. Quick research & found this.
Is there something else out there is the question.
Edit: Moderator
Realized this thread should be in Modification interior/exterior. Could you move it over? Thanks.. .
bahman
Feb 14, 2016 10:29 AM
Doc Pain
Oct 28, 2015 07:09 PM
Snotrocket555
Oct 1, 2015 08:59 AM
papawhiskey
Sep 30, 2015 02:50 PM
aldito2
Sep 30, 2015 10:44 AM
