R50/53 What length belt pulley Alta -15?
Old Jul 17, 2011 | 03:16 AM
leonetn's Avatar
leonetn
Sorry guys, with the pulley -15 alta belt which length (mm) should have to work well?
thanks
Old Jul 17, 2011 | 04:37 AM
HRM's Avatar
HRM
belt size you want to be using is napa 4060535
Old Jul 17, 2011 | 05:14 AM
leonetn's Avatar
leonetn
thanks HRM
Old Aug 16, 2011 | 08:21 PM
minimic's Avatar
minimic
i am getting mine installed tomorrow and alta gave me the 060539. i assume this will work as well.
Old Aug 16, 2011 | 08:51 PM
ZippyNH's Avatar
ZippyNH
the 539 will work...is easier to install...but once stretched is more likely to slip...(should be finethe though) no worries..just toss on a 535 length belt next time!!
Old Aug 16, 2011 | 09:36 PM
minimic's Avatar
minimic
really? wow. ok, well there is a napa on the way, so I wil pick up the 535 in the morning. thanks for your help!
Old Aug 17, 2011 | 01:47 PM
minimic's Avatar
minimic
well, i picked up a 535 this morning and the shop called a little bit ago leaving a message that the wrong belt (the one i bought this morning) was shipped. so he found the correct one locally (probably the one i returned) and said it would be ready by EOD. just curious, how long do serpentine belts last? when should i replace this one?
thanks for the help!
Old Aug 18, 2011 | 11:28 AM
minimic's Avatar
minimic
is this belt the correct one to use?
Old Aug 18, 2011 | 05:30 PM
MINI33342's Avatar
MINI33342
yes
Old Aug 19, 2011 | 07:44 AM
minimic's Avatar
minimic
i had an alta 15% sc pulley installed the other day on my 2006 MCSa, along with the alta tensior stop. everything went fine, but last night, i noticed at idle, there is a some rattling coming from the pulley area. when i put it drive or reverse, it gets a lot louder. is my belt tensior loose? or is it the tensior stop? they put on the 060539 belt, but at idle, the belt seemed to be turning fine, and the pulley was spinning very smoothly. should i swap out the belt for the 060535 above? i am going to record some video and post it up for you to hear.
any ideas???
Old Aug 19, 2011 | 02:13 PM
beken's Avatar
beken
any ideas???
It appears to me the NAPA belts are of fairly hard rubber. On my car, it sounds like the belt is slipping, but after a couple of minutes of warm-up, it goes away. It does that even with a brand new tensioner and new belt.
Old Aug 19, 2011 | 03:38 PM
minimic's Avatar
minimic
hmm, maybe its nothing. it sounds more like a rattle than a squeal. i'm going back to the shop next friday for them to check it out. it drives fine, but i didnt' want to hurt the car and need to solve the rattle, if possible. thanks for your comment!
Old Aug 19, 2011 | 06:36 PM
ZippyNH's Avatar
ZippyNH
If you feel aftermarket belts, you will notice they are a bit more pliable than the mini oem belts..
Strength...who knows, but most suggest replacing belts on cars with a pulley annually...there is simply a smaller area for the belt to contact the pulley...so even the expected wear rate is a bit higher on a pulley car....
Sometimes belts can squeal a bit to missalighnment.....
Some tensioner stops can add a bit of noise...the alta one made lots...was partially redesigned to help...the cable ones are silent.
Some folks have found that Goodyear gator back belts help if the missalighnment is minor...the backing is not thea traditional rib, but a series of shorter stripes.....
Old Aug 19, 2011 | 07:16 PM
minimic's Avatar
minimic
thanks for your input zippy. what do you mean by 'cables ones are silent'? if the issue is the alta tensior stop, should i look into a cable one?
Old Aug 19, 2011 | 07:39 PM
ZippyNH's Avatar
ZippyNH
If the noise is comming from the tensioner stop...it might need adjustment....but the nature of the alta stop is that it can vibrate...make sounds...
Detroit tuned, and a few others make a simple piece of cable, with a loop on each end...if the tensioner fails...it limits the amount it can extend to the length of the cable..
Simple...
Cheap...
silent...
Old Aug 20, 2011 | 09:39 AM
minimic's Avatar
minimic
i see what you mean. i put in an inquiry to chad about it. i am pretty sure its the tensior stop. thanks for your advice, zippy.
BernieCoop
Sep 10, 2021 03:15 AM
patsum
26
May 29, 2021 06:29 PM
bahman
Nov 15, 2019 05:45 AM
rtk90
Aug 29, 2019 09:08 AM
