R50/53 F39 Fuse Blowing after PSP Replacement
Old Jul 6, 2011 | 10:16 AM
ChilenFlame's Avatar
ChilenFlame
Hi, I have a 2003 MCS with 90K. I just replaced the PSP and Fan which was toast. I bled the system and everything was working OK after a test run. Today I did my usual 30 miles to work and the battery light came on and the PS went hard. The F39 fuse had blown which according the fuse diagram is a 5 amp fuse for the battery. I checked the fluids for the PSP and they were OK.
Can anbody help point me in the right direction with an explanation of what may be blowing this fuse. I replaced the fuse and all is well but I expect it may happen again.
Old Jul 6, 2011 | 07:22 PM
Hound_va's Avatar
Hound_va
Not sure if the fuse layout on an 03 is different than an 06, but F39 a 5a and is the for ASC/DSC in an 06. F38 is a 10a for the battery. Are you sure that it was F39 and it was for the battery?
Old Jul 6, 2011 | 07:51 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I've seen the rebuilt pumps blow fuses like that otherwise you have some other wiring problem.
triple5soul
21
Jul 29, 2016 04:27 AM
siriuszero
Sep 17, 2015 04:41 AM
milkrun49
Factory JCW Talk (2009+)
Aug 13, 2015 06:01 AM
Red Raven
Aug 11, 2015 04:48 AM
nismo4life
Aug 5, 2015 08:31 AM
