Recurring Code 2906?
Old Jul 3, 2011 | 04:15 PM
skrzastek's Avatar
skrzastek
Cleaned the MAP sensor and 10k later, no issues at all!
Old Jul 3, 2011 | 04:37 PM
Revolution Mini Works's Avatar
I believe you mean P2096
take out the map sensor in the intake manifold and clean it with maf/map cleaner and re-install... ADAPTATIONS WILL HAVE TO BE RESET WITH ...............
bavarian technic tool
autologic tool or GT1 tool for it to be gone after everything is fixed
Old Jul 3, 2011 | 05:02 PM
skrzastek's Avatar
skrzastek
You are correct, I meant P2096. I will try cleaning and find out where I can get the code reset.
Old Jul 3, 2011 | 05:13 PM
where in VA are you located? Might be able to find someone to reset it for you.
I have the tool to reset it if you can come to VIR around July 22nd
Old Jul 3, 2011 | 05:23 PM
skrzastek's Avatar
skrzastek
Waynesboro. Are you going to the UTCC?
Old Jul 3, 2011 | 05:25 PM
I hope to be there, we've been working on my Mini adding more HP and Aero
Old Jul 5, 2011 | 03:51 PM
skrzastek's Avatar
skrzastek
Will the Peake reader reset the code? I cleaned out the MAP as well as going under the car to check the O2 sensors. I really didnt like the way the wires where bent on the rear sensor so I straightened it out some (maybe heat plus extreme angle caused some of it?)
Old Jul 6, 2011 | 09:25 PM
Some Guy's Avatar
Some Guy
You need one of the 3 tools RMW listed, only way.
Old Aug 2, 2011 | 03:34 PM
jrla's Avatar
jrla
So......plese help!
...you are saying one of these tools will likely clear the light off the dashboard? my mechanic changed the map sensor, replaced both O2 sensors, reset the computer, did a partial tune-up, trying to get the light off but no go. I told him one of those tools might do the trick based on what I read but do you think resetting the computer wouldn't do the trick? i'm so frustrated because my emissions sticker expired and he can't inspect the car until that light is off...
J.R.
Old Aug 3, 2011 | 01:03 PM
jrla's Avatar
jrla
anyone out there?
I am going to pick up my 2004 MCS today. I went by my mechanic's shop earlier and he replaced the map sensors, changed the spark plugs, air filter, reset the computer, all after replacing both O2 sensors due to a 2096 code and the light is still on! Is anyone out there that has had this issue? If so, please let me know how to rectify it asap. It's a good thing it is garaged because the inspection sticker is expired
Old Sep 13, 2011 | 12:37 PM
skrzastek's Avatar
skrzastek
Cleaned the MAP and 10k later no issues!
Old Dec 17, 2011 | 11:11 AM
este1's Avatar
este1
where is the MAP sensor? i put a new air filter in and wanted to clean it but the tube coming out of the filter housing is almost impossible to remove at the bottom. is that where it is? still getting the lean condition 2096 code.
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
olson187
Sep 18, 2015 10:26 AM
Mini Hooper
Sep 17, 2015 01:58 PM
Enjoytheride
Sep 17, 2015 12:10 PM
