Suspension How to Lower with Just Springs
Old Jul 1, 2011 | 07:01 PM
MiniBOL's Avatar
MiniBOL
Hello NAM members. Is there any write up on how to lower the R56 with just the springs including torque specs?
Old Jul 1, 2011 | 07:10 PM
Maugre's Avatar
Maugre
Are you going to replace just the springs and use the stock dampers?
Which torque specs do you need?
Old Jul 1, 2011 | 07:22 PM
MiniBOL's Avatar
MiniBOL
Yes just replacing the springs with NM for now. Never did on a MINI so i just wanna make sure I do it right. I need to know if there are any write up/step by step process and torque specs for all the nuts/bolts.
BTW...I just saw a thread here from Alta re H & R springs installation but was wondering where I can get the torque specs.
Thanks!
Old Jul 1, 2011 | 07:34 PM
Maugre's Avatar
Maugre
Go to the NM site and you can download instructions on spring replacement. Full instructions w/torque specs if I remember right. Have the NM springs myself. If you have trouble finding specs, PM me and I will send you Inst. Good luck.
Old Jul 1, 2011 | 07:36 PM
MiniBOL's Avatar
MiniBOL
Will do. Thanks for the info. Dunno why I didnt think of that!
Old Jul 1, 2011 | 09:24 PM
MiniBOL's Avatar
MiniBOL
I couldn't find anything on NM but anyhow, would I need a 21 mm strut socket from BMW for taking out the strut mount nut? I saw a thread on how to here in NAM and list as one of the tools needed.
Old Jul 2, 2011 | 04:57 AM
onasled's Avatar
onasled
Impact gun! ;-)
Tourque specs are not "Mini" specific. They can be looked up on the internet as tourque specs go by bolt size.
Old Jul 2, 2011 | 08:39 AM
Maugre's Avatar
Maugre
Go to Sears and get whatever sockets you may need.
Torque specs are M8-10 ft.lbs. M10-19 ft. lbs. M12-34 ft. lbs. M14-54 ft. lbs. M16-83 ft. lbs. Hope this helps.
NM used to have that info but now I see for the springs it's gone?
patsum
26
May 29, 2021 06:29 PM
smdmini
Oct 7, 2019 06:05 AM
Supertractor3
Apr 7, 2017 11:16 AM
ej
Nov 17, 2015 09:21 PM
Sep 2, 2015 11:15 AM
